Dell precision 5520 It only starts with the battery disconnected and with the ac power not recognized message
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Already replaced adapter, battery and dock connector. If I only connect the adapter with the battery disconnected, it turns on with the message bios adapter not recognized. While if I connect both the battery and the adapter it doesn't turn on. When it turns on only with the adapter and I try to update the bios it tells me to connect the adapter! can being connected. If I connect the battery when it is turned on with the adapter it turns off. Do you have any ideas?
  • mon2
    • Dec 2019
    • 14255
    Review the PS_ID pin on the power adapter connector which must reach the EC by the way of a mosfet in the path.
    The adapter must be original with PS_ID pin support.
    Often the fault is in the mosfet but may be in the power adapter contact pin. Search out numerous cases on this forum with the same fault. Post back with your results and questions.
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      Sorry I had abandoned it, now I checked and the power supply is original on the psid pin of the adp100 connector there are 3.28V while on the battery 10.7V
      • mon2
        • Dec 2019
        • 14255
        What does the BIOS report for the adapter ratings? Still unknown?
        Review the center pin of the power adapter.
        Remove all power. Measure the resistance across PR903. Confirm this is ~33 ohms.
        • Fabbrone
          • Jun 2015
          • 158
          • italy
          I confirm that the adapter is not recognized Unfortunately I can't find pr903 ! from PL901 to PSID pin 4 of ADP100 there is 117K
          • mon2
            • Dec 2019
            • 14255
            Post clear pics of the areas linked to this power path.
            • Fabbrone
              • Jun 2015
              • 158
              • italy
ID:	3597561 Click image for larger version
              two affected area
              • mon2
                • Dec 2019
                • 14255
                Review these areas.
                Click image for larger version  Name:	suspects.png Views:	0 Size:	1.75 MB ID:	3597571
                • Fabbrone
                  • Jun 2015
                  • 158
                  • italy
                  they are traces of glue or dust they are not compromised components
                  • mon2
                    • Dec 2019
                    • 14255
                    What are the 'LA-****' silk screen markings on your board? This will identify the logic board model.
                    Found a few schematics that appear to be linked to this 5520 series.
                    • Fabbrone
                      • Jun 2015
                      • 158
                      • italy
                      CAM00/01 LA-E331P REV 1.0
                      • mon2
                        • Dec 2019
                        • 14255
                        Good. What is the resistance across PR102? No power to the board / no battery when checking in resistance mode.
                        This should be ~33R = 33 ohms.
                        • Fabbrone
                          • Jun 2015
                          • 158
                          • italy
                          Oops there is 1,2k !
                          • mon2
                            • Dec 2019
                            • 14255
                            Either replace this part with a 10-100 ohm resistor or just solder short the pads to bypass this component. Test again after this mod.
                            • Fabbrone
                              • Jun 2015
                              • 158
                              • italy
                              Done and left again calmly, the resistance was broken!
                              • mon2
                                • Dec 2019
                                • 14255
                                Working now? Adapter is recognized?
                                • Fabbrone
                                  • Jun 2015
                                  • 158
                                  • italy
                                  Yes Great Lun2, it starts normally without message and charges the battery. many thanks
                                    DELL Precision 5520 Mobile workstation 5000 Specification for Upgrade or Repair
                                    This specification for the DELL Precision 5520 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5520 boardview and 5520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                    09-06-2024, 06:50 AM
                                    09-06-2024, 06:48 AM
