Acer Sf314-41 power issue
  • claws77
    • Apr 2024
    • 103
    • India
    my laptop has a weird power-on issue.
    Once the laptop has been powered on, it can restart/ wake just fine on battery power or Adapter, ONLY If i have not closed the LCD.
    If i am running on battery and have closed the LCD (even momentarily). it will not power-on/ wake-up on battery power no matter the battery percentage.
    but once i open the LCD and connect it to the adapter (even momentarily) it will wake up gain and I wont experience any issues till i close the LCD.
    i do not know where to look for repair.
    thank you all for any advice.​
  • mon2
    • Dec 2019
    • 14662
    Can you link the schematics for this board? Only if they are in the dedicated schematics forum.
    • claws77
      • Apr 2024
      • 103
      • India
      https://www.badcaps.net/forum/troubl...bow-pk-18848-1
      this webpage has them.
      • mon2
        • Dec 2019
        • 14662
        Review the voltage to ground of the LID_CLOSE# signal. Since there is a '#' suffix in the netname, this is an ACTIVE LOW signal. This means that if this line is logic LOW = ~0 volts, then the LID is considered to be closed. Respectively, if the LID is open, this signal line should be pulled to a logic HIGH level of ~3v3 through pull-up resistor @ R2468. If you do not see these states, then review the voltage on each side of R2468.
        Post each measurement.
        • claws77
          • Apr 2024
          • 103
          • India
          Click image for larger version  Name:	LID_CLOSE#_PU.png Views:	10 Size:	176.3 KB ID:	3263730
          sir, i have reviewed AFTP72 which is connected to pin 1 of LID_CLOSE#
          Click image for larger version  Name:	image.png Views:	0 Size:	131.6 KB ID:	3264561
          my findings
          on battery power this point reads 0.068V (Black probe to GND, red probe to test point of multimeter) in closed state of LID but when i open the LID this point still reads 0.068 V on battery power
          on AC power, this point reads 3.312V. in open LID position
          once AC power is removed in LID open state it still reads 3.312 V on battery power.
          so yes this LID_CLOSE# signal is faulty. Thank you. How to repair this? Sorry for delay in reply
          • claws77
            • Apr 2024
            • 103
            • India
            IOBD 1 is the problem, removing it solves the problem.
            reconnecting it makes the problem come back.
            how to repair this board?
            strongbow_KL_LED_CARD_MB 17824-1
            • mon2
              • Dec 2019
              • 14662
              See attached. Confirm that your RTC battery is ok - may need to be replaced. This is required to create the pull-up voltage when the power adapter is absent.
              Also confirm that the dual common cathode diode @ D2501 is functional. You can check it with DIODE mode of your meter. Remove all power. Meter probes on each anode / cathode pair; diode should conduct in one direction but block if the meter probes are reversed (cathode / anode). Repeat for the other diode inside this sot23-3 package.
              • claws77
                • Apr 2024
                • 103
                • India
                RTC battery voltage is 3.096 V
                D2501 is ok? reads .288 in one direction and OL in reverse polarity. for both pairs 1-3 and 2-3
                on just RTC connected pin 2 is 3.09 V and pin 1 is 0, pin 3 is 2.976V
                I think that the issue is daughter board. removing it the laptop turns on fin even on batttery power and the voltage at ATFP72 is also ok but connecting the IOBD 1 the voltage drops to 0.68 V.
                • mon2
                  • Dec 2019
                  • 14662
                  What is on this iobd? Are there schematics available for this add on board? With no power, mate this board and check the resistance to ground of this lid sensor pin. You can also test in diode mode. Inspect this board for any physical damage.
                  • claws77
                    • Apr 2024
                    • 103
                    • India
                    IOBD seems to be I/O board, it has a usb port, card reader. LEDs. Fingerprint. there are no visual damages.
                    There is no schematic available for this board
                    the resistance to GND is 142.1 kohm
                    removing the IOBD AFTP72 shows 0 V on RTC and 3.303V on RTC + Battery
                    attaching the IOBD AFTP72 shows 0.77 V on RTC and 0.68V on RTC + Battery
                    • mon2
                      • Dec 2019
                      • 14662
                      The same 3v3 rail from pin #3 dual diode must be used by this defective iobd.
                      Confirm it with the boardview file that this iobd connector uses this low current rail.
                      Then check the resistance to ground of this rail with and then without the iobd plugged in.
                      Post pics of this iobd. Someone is shorted onboard. Could be a tvs esd device used by the usb port or card reader.
                      • mon2
                        • Dec 2019
                        • 14662
                        See attached. With your meter in DIODE mode and without any power to the board -> connect your IOBD. Then proceed to measure each contact on this connector in DIODE mode. Red meter probe to ground, yes RED. Black meter probe to the pin to test.
                        We are hunting for any line with a low measurement which means that line is shorted and is of concern. Post your measurements.
                        • claws77
                          • Apr 2024
                          • 103
                          • India
                          Click image for larger version  Name:	iobd.png Views:	0 Size:	147.4 KB ID:	3264825
                          Click image for larger version  Name:	image.png Views:	0 Size:	34.0 KB ID:	3265098
                          third column is with reference(red probe) to daughter board's usb casing.
                          4th collumn is with reference(red probe) to main board's usb casing.
                          • mon2
                            • Dec 2019
                            • 14662
                            To confirm, the iobd is disconnected and the measurements were taken.
                            Then the iobd was attached and the measurements were taken again.
                            Is this correct?
                            Confirm the measurement of pin #23 on the iobd connector.
                            • claws77
                              • Apr 2024
                              • 103
                              • India
                              you are right 3rd column 7 is OL and 23 is .555
                              • mon2
                                • Dec 2019
                                • 14662
                                Measure the voltage to ground of pin #8 with and without this iobd board.
                                • claws77
                                  • Apr 2024
                                  • 103
                                  • India
Name:	Screenshot 2024-05-05 192845.png
                                  Green means Repeatable values
                                  inc means increasing
                                  dec means decreasing
                                  non colored values means that they are non zero but change as i keep measuring it 2nd and 3rd time
                                  both colums are measured 3 times to check for repeatability.
                                  • mon2
                                    • Dec 2019
                                    • 14662
                                    See attached. The signals marked with the red arrows are shorting out once you attach the IOBD.
                                    Start with the USB4 connector -> nearby may be a TVS ESD diode array. Share close up pictures of this region. That part should be removed and then the USB4 signals should return to a normal range. This may also correct the voltage rail on line # 8.
                                    • claws77
                                      • Apr 2024
                                      • 103
                                      • India
                                      ​thank you greatly for giving your time to help me. many thanks
                                      • mon2
                                        • Dec 2019
                                        • 14662
                                        See attached.
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • Mirenia
                                          Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                                          by Mirenia
                                          got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                                          The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                                          If this happened once, then the laptop only runs for a few minutes until restart.
                                          This happens regardless while staying in windows or uefi or in a linux environment.
                                          At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                                          01-05-2025, 05:15 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          08-02-2025, 06:39 AM
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
