Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
  • joesmoe91
    • Oct 2016
    • 7
    My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights. However, after turning on for about 1 second it then shuts off. Also looked at it again with the thermal camera and nothing is getting hot now.
    Have a good amount of hardware experience but not so much computer architecture and which voltages need to be what in order for things to work correctly. Took the measurements below so far, but can take whatever other measurement you think would be useful.
    When I say "briefly" I mean that voltage reads 0V until I press the power button and then the voltage appears briefly before dropping back to 0V when the computer turns off. Resistances obviously measured with power disconnected
    Thanks for any help
    B+ 13.52V
    VALW 1.053V (briefly)
    1.2V_DDR 1.195V (briefly)
    1V_PCH 1.053V (constant)
    GPU_Core 1.8 Ohm to Ground
    0.8V (briefly)
    VCC Core 3.2 Ohm to ground
    1.05 V (briefly)
    1.8_PCH 1.86V
    1.8_PCH_LDO 0.63v (Resistor rh5880 not populated)
    1V_PCH_PRIM 1.053V
    https://www.mouser.com/ProductDetail...6VEJNV1A%3D%3D
  • mon2
    • Dec 2019
    • 14219
    Hi. Suggest to read the sticky above on charger circuits by piernov. Then carefully check the voltage to ground of the DCin mosfets.
    being a Dell product, the single wire ADAP_ID is critical. Check the voltage to ground of this line. Without proper adapter ID detection will fail.
    • joesmoe91
      • Oct 2016
      • 7
      Went back and traced through some of the charger circuit. Saw 19V on DC_IN but not on SDC_IN or DC_IN_SS. Could be reading this schematic wrong, but doesn't it seem like I am missing this 0ohm resistor to PQ205 gate that pulls down the PQ200 gate and turns S1 on?
      • mon2
        • Dec 2019
        • 14219
        The missing 0 ohm resistor could now be just a pcb trace to save on cost. Check with no power and meter in resistance mode. Measure the resistance from the logic gate to this mosfet gate pin.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          PU1252 is a dual n channel mosfet i beleive(not looked into schematic/bv) and if it was shorted,there is high chances that cpu got damaged.
          PS: I dont see any merit in troubleshooting charging section as almost all major rails are rising which is a proof enough that B+ is generated correctly.
          • joesmoe91
            • Oct 2016
            • 7
            You were right about the missing 0 ohm and the pads measure short across.
            I am no longer getting fan spin or lights when I hit the power button and +B is 1.6V now (instead of 13.5). If the CPU was damaged and dying I could see trying to repeatably restart the computer finally cause it to kick the bucket. Not sure where to go from here.
            • Herby94
              MacBook Pro A1707 Won’t Boot – No Display, Fans Spin Briefly
              by Herby94
              I’m currently having an issue with my MacBook Pro (A1707). It doesn’t power on or make any sounds.
              • The charger is a generic third-party unit that had a loose connection at the AC input (127VAC). I fixed it, and now it delivers 20VDC to the laptop.
              • When connected, the fans spin for about 30 seconds before shutting off.
              • No display, no audio, and no signs of life during this time.
              Any ideas? Could this be a logic board issue, or is the charger still a problem? Thanks in advance!...
              08-07-2025, 08:59 AM
            • emil_t
              RTX3090 working fine but fans not spinning
              by emil_t
              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
              04-12-2024, 06:54 AM
              DELL G15 5530 Notebook Specification for Upgrade or Repair
              This specification for the DELL G15 5530 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5530 boardview and 5530 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL G15 5530 Notebook...
              09-07-2024, 07:12 AM
