Dell Inspiron 7567 LA-D993P Battery percentage
  • rob777
    • Apr 2016
    • 12
    Hi guys looking for some help. Losing my mind over an old machine I'm trying to get going and cannot. It's a Dell Inspiron 7567 LA-D993P.
    Problem was it was not charging. One of the dc-in mosfets had died. So I replaced all 5 of the 6 mosfets in charging circuit. Also replaced bq charging ic.
    Laptop powers on and recognises charger but battery percentage never increases. Laptop will run on battery power only but can't get past 4%.
    I've uploaded the schematics if anyone can help. Page 55. [MOD EDIT] Link to schematic -> https://www.badcaps.net/forum/troubl...ematic-request
    Hopefully I can get this going again. Really appreciate any help given.
  • mon2
    • 14832
    The battery gauge is handled using the smbus scl and sda lines on the battery pack. Measure the voltage to ground of each of these important lines, scl and sda. Post each measurement.
    • rob777
      • Apr 2016
      • 12
      Thank you. SCL and sda measure .418 and .465. That’s diode mode red probe on ground.
      After more probing I’ve found PQ304 isn’t opening. I have 19v coming in. Nothing coming out and 11.01v on enable pin DH_CHG. Betting this is bleeding obvious and staring me in the face.
      • mon2
        • 14832
        Diode mode checks are ok. So these lines are not shorted.
        Check your high side mosfet in resistance mode. Remove all power. Meter in resistance mode.
        Check the resistance across this mosfet:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each measurement. A low resistance reading often means the mosfet is shorted / leaky and must be replaced.
        • rob777
          • Apr 2016
          • 12
          Thank you. PQ304 high side mosfet is one of the ones I have already replaced.
          Source to gate - 480k
          source to drain - 390k
          drain to gate - 200k
          PQ305 the smaller mosfet which sits underneath and is connected to PQ304 has not been replaced. It’s readings are:
          Source to gate - 198k
          source to drain - 42k
          drain to gate - 440k
          Is that 42k resistance too low and showing that pq305 needs to be replaced?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            PQ301/302-Voltage on Source/gate/Drain?
            Cgarging IC-VCC/REGN?CMSRC/ACDRV/ACOK/ACDET-Voltage on these pins?
            • rob777
              • Apr 2016
              • 12
              Thank you. Voltages measured:
              pq301 19.3/25.5/19.3
              pq302 19.3/25.5/19.3
              pin 28 vcc 19v
              pin 24 regn 6.09v
              cmsrc - 19.27
              acdrv - 25.5
              acok - 3.353
              acdet - 2.671
              from what I understand reading the laptop charging circuit sticky is all these voltages are correct? ACDET the only one I’m not sure what that voltage is supposed to be or whether correct.
              • mon2
                • 14832
                Yes 42k looks low. Consider to flux and remove this mosfet. Then allow it to cool on your work table. Measure the resistance again of this removed mosfet. Do not power up the logic board without a low side mosfet. Compare the resistance to a fresh mosfet.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Measurements at post#7 are all correct. ACDET should be above 2.6V
                  • mon2
                    • 14832
                    Is this Dell power adapter the proper one for this chassis? You could modify the resistor based voltage divider so that the ACDET pin will rise above 2v7 (check the datasheet for the charger for this threshold value) to pacify the detection circuit but in theory it should not be required.
                    • rob777
                      • Apr 2016
                      • 12
                      I have removed mosfet. Gate to source and gate to drain I cannot get a reading on. OL both ways.
                      drain to source is 12.3m ohms.
                      I don’t have another mosfet to compare with. Going to have to purchase something and hope this is the issue.
                      The PQ305 is a AON7518 of which I can’t find a data sheet and is also obsolete however on digi key it says the AON7380 is a direct replacement for the 7518.
                      Then I find the 7380 is also obsolete. Comparing data sheets aon36368 is similar. I have attached both data sheets. Can I get confirmation it will be sufficient to use 36368 in its place? Thanks again for everyone’s help.
                      • rob777
                        • Apr 2016
                        • 12
                        started with a little 90w charger. Then used a 180w and still unsure I bought a 240w charger. No changes with any of the reading around the bq chip with any of those chargers. These are not original chargers though.
                        • mon2
                          • 14832
                          Does the bios report that a different power adapter is plugged in?
                          review the voltage to ground of each pin on pq100. Post each measurement.
                          dell adapters use a single wire communication to identify the power adapter. This is the PS_ID line.
                            DELL Inspiron 7567 Notebook 7000 Specification for Upgrade or Repair
                            This specification for the DELL Inspiron 7567 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7567 boardview and 7567 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 7567...
                            09-06-2024, 08:01 AM
