HP Envy 15 doesn't charge or work only with AC.
  • maaw
    • Feb 2013
    • Argentina
    Hi, I own an Envy 15 1100cto refurb which stopped charging after ~1 year of use. It originally came with a 65w ac adapter, but after reading the users guide, i learned that the i7 ver. needs a 120w ac adapter, so i bought a LiteOn generic adapter which worked perfectly out of the box. A year later, my battery was about to end so I went and plugged the laptop, but it didn't start charging (no amber nor white light, just nothing). Took the laptop and the adapter to some pc service and they said the adapter's low voltage wire was cut and fixed it. The lappy went back to life for a week or so. Again, the same problem. No led indicator. Took the adapter back and the guy said the adapter was fine, and that they couldnt check anything else. Bought a new HP adapter which worked like 4 o 5 minutes and then the same. So I disassembled the envy and found that the smart (center) pin voltage drops to 0 when I plug it. Is this normal? What else can I check?
    The laptop runs fine on battery...
    Thanks in advance
    Mariano.
  • Tuomo
    • 163
    • Finland
    Re: HP Envy 15 doesn't charge or work only with AC.
    Thanks in advance
    Mariano.
    Because the charger does not work, then it probably should have a higher voltage.
    Some charger have chip which communicate with KBC , but this case I dont know.
    Can you measure resistance to center pin?
    • maaw
      • Feb 2013
      • Argentina
      Hi, thank you for your answer Do you mean in the charger or in the laptop?
      • Tuomo
        • 163
        • Finland
        Check a few things.
        laptop center pin, you should check if it is shorted.
        Check voltages on PQ22 pins.
          HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
          This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
          09-06-2024, 06:50 AM
          HP ProBook 650 G3 + USB-C Universal Dock w/4.5mm Adapter Notebook 600 Specification for Upgrade or Repair
          This specification for the HP ProBook 650 G3 + USB-C Universal Dock w/4.5mm Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G3 + USB-C Universal Dock w/4.5mm Adapter boardview and 650 G3 + USB-C Universal Dock w/4.5mm Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
          09-06-2024, 06:48 AM
