acer aspire 5570 display problem
    The display comes on external monitor but not comes on lcd of laptop.i also checked light but it also not comeing on
    Re: acer aspire 5570 display problem
    have you shone a torch into screen to see any image
    it may be smd fuse on the inverter, faulty inverter, also may be faulty ccfl in screen,or faulty screen,
    check to see if there is a smd fuse to screen, check inverter connectors
    those are the easy ones to check first
      To test the inverter put your DMM into the Herts position next place the probes about 5mm apart from each other, then as close as possible (but not touching) put them to the output or around the inverter and see if there any reading. If there's reading then ccfl backlight is bad. If no reading check voltage coming into the inverter. You can do this simple test without removing the front lcd bezel.
        reball the gpu.
          today an acer 5510 came to me it has the same problem, i'll work on it tomorrow if i find a solution i will write it here.
            Originally posted by spidey View Post
            reball the gpu.
            If it were the GPU, there would be no display at all, be it external or your laptop screen.
            1> Could be the LCD CABLE
            2> LCD Inverter
            3> or the board.
            http://nishantpinto.blogspot.in/
              2> LCD Inverter
              3> or the board.
              As i know inside the GPU there are different parts wich command external Display and also command it own display. if the own display part is harm, so reballing should help .
                i changed the lcd inverter and the problem solved, you should try..
