hp probook 6570b no power
  • dqtech
    Badcaps
    • Jul 2018
    • 639
    • N/A
    the problem is 3v and 5v not present....i've check on controller ic Tps51125a (u1001), vreg3 0v and vreg5 only read 1.8v...any help?
  • mon2
    • Dec 2019
    • 14665
    Re: hp probook 6570b no power
    Schematics should be posted only in the dedicated schematic forum and linked here. It will make it easier to locate by future readers.
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of vreg5 (since it is not the full 5 volts).
    Repeat for vreg3.
    Post both measurements along with the resistance scale / units.
    • dqtech
      Badcaps
      • Jul 2018
      • 639
      • N/A
      Repeat for vreg3.
      hi sir....sorry i give wrong information at the beginning....this is the right measurement....vreg3 read 1.8v (resistance 50k ohm) and vreg5 read 0v (resistance read short 4 Ohm only)
      sorry i cant edit post for that schematic....here the link https://www.badcaps.net/forum/showth...61#post1273961
      • mon2
        • Dec 2019
        • 14665
        Vreg5 has a shorted component on this rail.
        Use a dc power supply dialed to 1 volt (not higher) and inject this voltage onto the vreg5 rail.
        No other power to the logic board. This part at 4ohms should start to heat up.
        (Revised)
        • dqtech
          Badcaps
          • Jul 2018
          • 639
          • N/A
          (Revised)
          can inject on this SL1001 right?
          • dqtech
            Badcaps
            • Jul 2018
            • 639
            • N/A
            feel a bit warm on controller ic 51125A (U1001)
            • mon2
              • Dec 2019
              • 14665
              Locate the pcb pad at SL1001. It is very likely to be a small trace between pads. If it is a part (0402) on the pads, flux and remove it. Sometimes, the 0 ohm in an 0402 package is used as a jumper. By removing or cutting this connection, the vreg5 rail will be isolated from the load side.
              If it is a PCB trace, you can consider to cut the trace for a quick test. Afterwards, you can solder blob the cut trace pads to restore back to original.
              Then measure the resistance to ground again of this vreg5 rail with the cut trace.
              The fault may be with this regulator IC or a component on this power rail.
              • dqtech
                Badcaps
                • Jul 2018
                • 639
                • N/A
                i remove jumper SL1001, vreg5 read 47 Ohm....restore back to original read only 4 Ohm
                • dqtech
                  Badcaps
                  • Jul 2018
                  • 639
                  • N/A
                  problem solve....i replace that regulator IC and everything work fine...thank you sir
                    HP ProBook 6570b 6000 Specification for Upgrade or Repair
                    This specification for the HP ProBook 6570b can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 6570b boardview and 6570b schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 6570b is accurate,...
                    09-06-2024, 05:27 AM
                    HP ProBook 6570b Notebook 6000 Specification for Upgrade or Repair
                    This specification for the HP ProBook 6570b Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 6570b boardview and 6570b schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 6570b...
                    HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-07-2024, 07:12 AM
                    09-07-2024, 06:40 AM
                    HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                    This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                    09-07-2024, 05:50 AM
