Hope someone can guide, having a hard time finding where to find the issue of this laptop, it comes on and off for a second looping. Ivecheck the 3v present 5v is missing but if power pressed the 5v is stable not pulsing . Is it a bios issue? Im currently not sure if its is, need to buy programmer first if that so . hope some have a hint
Acer da0zqmmb6f0 rev f
Re: Acer da0zqmmb6f0 rev f
Originally posted by mcplslg123 View Post5V will appear on coil only after triggering-so that's fine. Are you getting display for a brief moment or it just turns on and off without display?
Have a look at Page33 of schematic
ive tested all resistor inside the page 33 all in good reading no shorted and low resance on all PQ
SYS_SHDN# -3.2V
PQ15- PIN 3 - 9.2V
TEST PU10A
OFF STATE
1-0V 2.8mOhms
2 -5.1v stable
3. 2.3v
4,5,6- gnd
7- NC
8 - 0V
ON STATE
1. 0V
2.4.3V
3.2.3V
4,5,6- gnd
7- NC
8 - 19VLast edited by kalilinux25; 07-25-2023, 12:17 AM.
After tesing the mosfet Ive focused on the ram voltage ic , due I have a hint and remove the 2 mosfet to test for low resistance PQ27 AND Pq26 but after test mosfet was fine and Put everything back and retest again. Unit works!! due mybe to cold solder joint of the mosfet?
