ASUS G14 GA401QM Charge Light w/ No Power On
  • ResoluteHawk
    • Nov 2021
    • 154
    Re: ASUS G14 GA401QM Charge Light w/ No Power On
    Yes initially when plugged in Pin 1 on R3033 is 3.362V and pressing the button button drops it to around 3.2V but then it goes back up.
    Just to make sure the power button yields a response, if I hold the power button down for 20 seconds while plugged in, the voltage drops to 0 and almost instantly goes back up to 3.362V but the orange charge light turns off.
    • Sephir0th
      • Oct 2020
      • 1282
      Okay, it seems the logic requirements are met to start the board. however, before digging to deep, overview of the present voltages and resistances to GND please: PL8301, PL8401, PL8701 and PL8702
      To not miss a partial short to GND or similar.
      FairRepair on YouTube
      • ResoluteHawk
        • Nov 2021
        • 154
        PL8301 => 0.757V and 60 Ohms
        PL8401 => 1.84V and 613 Ohms
        PL8701 => 5.1V and 346 Ohms
        PL8702 => 3.36V and 3.54K Ohms
        • Sephir0th
          • Oct 2020
          • 1282
          It is a important lesson, to not overlook the simple things before digging to deep and get lost this way.
          So I suspect a partial short at the 1.8V and at the 5V rail. However, the short of the 5V rail is more clear but still not low enough to have much current draw.
          For the next step you need a bench top PSU and a thermal camera
          • ResoluteHawk
            • Nov 2021
            • 154
            OK I have both. Yeah shoot I don't know how I missed doing this step but the below did contribute to it.
            I typically don't inject voltage unless it's a dead short. Low resistance usually never has any results with voltage injection.
            Here's the weird thing. When I measured the 1.8v coil in resistance mode, I got the 613 Ohms. I had to move my hand though so I took the probe off and then put it back on the coil. When I did, it measured 1.9K Ohms. When seeing if I could replicate it, I found that I could do this multiple times and the same thing always happened.
            The 1.8v rail is the only voltage rail that exhibits this behavior. I've made sure it wasn't my multimeter probes by trying different probes and the same thing happens. Every other voltage rail has a constant resistance measurement.
            • ResoluteHawk
              • Nov 2021
              • 154
              So I injected 1V at 1A into the 1.8V coil (PL8401), and I noticed a heat spot coming from PU8401. I looked at the rest of the board but no other heat spots are present; not even on the CPU.
              Just to make sure the correct voltage was present, I then upped the voltage to 1.8V which is supposed to be present on the coil and still PU8401 was the only spot getting warm. Board was drawing 1A at 0.78V and PU8401 was at 100-110 degrees F.
              CPU still didn't show any heat spot with 1.8V.
              • Sephir0th
                • Oct 2020
                • 1282
                Okay, you're likely on something. However, if I remember correct I have advised to check the 5V rail first since the 1.8V rail was inconclusive in my opinion.
                • ResoluteHawk
                  • Nov 2021
                  • 154
                  Ok, so if I inject 1V into the 5V coil (PL8701), PQL8701 gets warm. Resistance from Drain to Source on this is 300 Ohms; taking it off the board and the resistance at the 5V coil goes up to 4.5K Ohms. Measuring the MOSFET in resistance mode from Drain to Source after taking it off and letting it cool yields ~350 Ohms so I think this needs to be replaced as that is way too low.
                  I also have working board that I just got today. Tested this one and the resistance on the 1.8V rail is 2K Ohms. That sounds like more of a healthy value. 5V rail is ~4.8K Ohms.
                  If I do the exact same thing with injecting 1.8V at the same amperage on PL8401, the same IC (PU8401) gets warm, and it still draws 1A at 0.78V but the board works and posts and I get into Windows and everything is recognized without issues.
                  • ResoluteHawk
                    • Nov 2021
                    • 154
                    New development. And this is just strange. I thought we had a clear fault with either the EC or PCH, or both. SUSB# and SUSC# were never present.
                    I don't know how many times I plugged in this board but today I thought I would take some measurements around the EC in voltage and resistance mode and compare them with a working board.
                    When I plugged in power, the board started and fans started spinning, as well as the white power led coming on. It got all the way into the BIOS as well.
                    In the words of Sorin from Electronics Repair School: Proper Weird.
                    • Sephir0th
                      • Oct 2020
                      • 1282
                      Maybe a intermittent issue with the +5VSUS buck converter. It might appear again soon.
                      • judamex
                        Asus ROG Zephyrus G14 GA401QM Won´t charge
                        by judamex
                        Hello, I have an Asus ROG Zephyrus G14 GA401QM which had a short circuit in the BQ24800 and would not turn on. The BQ24800 was replaced and now it turns on with the charger, but does not charge the battery. I have schematics and boardview, I checked mosfets and basic signals, but everything seems to be fine. The output voltage to the battery does not exceed 1V
                        02-05-2025, 01:05 PM
                        ASUS ROG GA401QM-K2065T Notebook Zephyrus G14 Specification for Upgrade or Repair
                        This specification for the ASUS ROG GA401QM-K2065T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-K2065T boardview and GA401QM-K2065T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 03:10 AM
                        ASUS ROG GA401QM-K2068T Notebook Zephyrus G14 Specification for Upgrade or Repair
                        This specification for the ASUS ROG GA401QM-K2068T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-K2068T boardview and GA401QM-K2068T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        ASUS ROG GA401QM-HZ279 Notebook Zephyrus G14 Specification for Upgrade or Repair
                        This specification for the ASUS ROG GA401QM-HZ279 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-HZ279 boardview and GA401QM-HZ279 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-07-2024, 02:50 AM
                        ASUS ROG GA401QM-K2196T Notebook Zephyrus G14 Specification for Upgrade or Repair
                        This specification for the ASUS ROG GA401QM-K2196T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-K2196T boardview and GA401QM-K2196T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
