HP zbook 440
  • ersiahmetaj
    • Jun 2022
    • 19
    • albania
    HP zbook 440
    I have a zbook 440, no display, i have tried to change all components and it still doesn't work. When I change cpu it starts when i press the power button but no display, but with its old cpu it starts without pressing the power button. Any idea ?
  • Big Pooka
    Need help with a Samsung UN60EH6003
    by Big Pooka
    Hello All,
    I'm a hobbyist at best, I've built a few radio kits (I'm a Ham), but other than that I'm a newbie at electronics.
    A friend gave me a Samsung UN60EH6003 that works about 50% of the time. Specifically, it demonstrates the common Samsung dreaded dead screen and blinking standby light when you try to turn it on. To be more specific, 50% of the time when you press the power button it starts normally, 50% of the time when you press it the screen does not come on, there is no startup tune sounded, and the red standby light blinks slowly.
    When it...
    05-27-2023, 12:39 PM
  • bembeno
    DELL percision 7510 when press power button not turnoff
    by bembeno
    DELL percision 7510 when i press poweron its startup normally but when press power button its not turnoff
    i updated thd bios under windows but the same
    01-01-2023, 10:37 AM
  • ebj423
    asus b75m-plus PSU turns on but no POST. Reset button starts it ?
    by ebj423
    Posted Today, 07:34 PM
    , Hi! In the normal startup process, my pc's power led will turn on, the hdd led will flash brightly for a moment, then beeps once and you would know that everything is starting up fine. But recently, it will just flash dimly(sometimes too dim to see) and then nothing, no beep to show it is posting but the psu is on and all fans/hdds/peripherals/usb are on, even the lan port is flashing. Luckily, I discovered that pressing the reset button after the power button will initiate the post (the hdd led will flash brightly, beeps once and everything starts up fine),...
    06-02-2022, 06:05 AM
  • MyBrainIsAStrainer
    Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
    by MyBrainIsAStrainer
    Hi!
    I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
    Symptoms in detail:
    1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
    2. I press power button. The board boots without issues.
    3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
    4. Push power button again, board boots fine.
    5. This shutdown/powerup can be repeated multiple times without problems.
    6. BUT: If I do a restart instead
    06-25-2023, 02:44 PM
  • thesame
    Navitel R1000 GPS camera bricked while updating, dump needed.
    by thesame
    This camera was flashed by the owner and after update it starts displaying NAVITEL and that is all.
    I have contacted Navitel help , they sent me one file called SdFwCode.bin and the firmware SD_CarDV.bin which i have uploaded here in a zip file together with a backup of the actual dump thats on the camera.
    These two bin files they say that i have to copy into an microsd card formated fat32 not bigger then 32Gb and to install the card into the camera.
    So first i had to press the M button on the camera , while keep pressing it i have to plug power cable into camera then press...
    08-23-2023, 06:02 AM
