Lenovo Y700 Gaming laptop not working
  • Reda123456
    hi
    • Jan 2022
    • 89
    • iraq
    Hello my laptop is Lenovo gaming laptop y700 its problem that when i plug the ac adapter the battery indicator keep flashing orange light and when i press the power button its have a white light for second and then nothing happened and the white light go away and
  • mon2
    • 14660
    Re: Lenovo Y700 Gaming laptop not working
    Hello. What is the logic board # ? Is it NM-A541 ?
    Review the usual DCin mosfets to check if they are being enabled.
    Charger IC is the common TI / BQ series so check the voltage to ground of:
    REGN ; pin 24
    ACDET ; pin 6
    ACDRV ; pin 4
    ACOK ; pin 5
    VCC ; pin 28
    Post each measurement. Often, the 2nd DCin mosfet starts to leak and causes these faults. If ACDRV is not ~25 volts then the fault is in this area of the logic board.
    ACDRV = adapter voltage + REGN voltage = ~19v + ~6v = ~25 volts to enable the 2 x DCin N-channel mosfets.
