ASUS GA401II-HE154TS BSOD on Adapter only
    I received this PC with severe liquid spill and burnt edp cable+connector. I've thoroughly clean the liquid spill,replaced all the parts affected by liquid,replaced a new edp cable and soldered a new edp connector. The mb now boots fine to windows and it works all day without any issues(BUT on battery only).
    It does charges the battery perfectly. The problem is i get BSOD(with different messages) on adapter only. The adapter is not faulty as i tested it on another asus tuff gaming laptop and its recognised properly.
    Could it be an issue with GTX1050? I tried installing MSI Afterburner but it refuses to open and gives some error
    "the application has failed to start because its side-by-side configuration is incorrect"
    Its related to visual C++ redistributable package as per some forums. I installed/repaired these packages but didnt helped. WIN11 clean installed with all updates installed-same issue.
    Any ideas??
    Re: ASUS GA401II-HE154TS BSOD on Adapter only
    Managed to fix it with msi afterburner installed. Installed Win10 and msi afterburner got installed without any issues.
