Dell Latitude E5450 LA-A901P no BIOS voltage
  • BMCappelletti
    • Nov 2021
    • 151
    • Brasil
    Hello.
    I'm trying to toubleshoot a Dell Latitude E5450 that, at first, did not have any sign of life.
    Charger would go into protection mode and I was able to find a bad cap (PC717 in the boardview file attached). I removed it and now I have a white light on power button, but it turns on and off, after about 15 seconds.
    I can find 19V, 5V and 3.3V coils but I could not find 3.3V in the BIOS chip (this model has just one).
    In the schematic (also attached) I can see the BIOS is component UC2 and 3.3V should come from +3.3V_SPI. Is that right?
    But I cannot find 3.3V on any of the connected points the boardview shows me.
    Also I have no voltage on the following components.
    These SPI_PCH_DO2 and SPI_PCH_DO3 are on the component JSPI1, which has no voltage on any PIN also, neither on those RC components.
    Well... after that I managed to trace the component UZ8, where I cannot find 3.3V on pins 13 and 14.
    So... what should I look for, now?
    What did I miss and what did I do wrong?
    ANY help is much appreciated.
    Thank you.
  • JaroTech
    • Mar 2015
    • 351
    Re: Dell Latitude E5450 LA-A901P no BIOS voltage
    Hi, what voltages do you have on pins 1, 3 and 4 of UZ8?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Besides pins mentioned by#jarotech,measure voltage on pin5 also. Resistance to GND on pin13-14 of UZ8?
      • BMCappelletti
        • Nov 2021
        • 151
        • Brasil
        Originally posted by jarotech
        hi, what voltages do you have on pins 1, 3 and 4 of uz8?
        1 - 3.3v
        2 - 3.3v
        3 -
        4 - 5
        5 - 3.3v
        6 - 3.3v
        7 - 3.3v
        8 - 3.3v
        9 - 3.3v
        10 - 8.9v
        11 -
        12 -
        13 -
        14 -
        • BMCappelletti
          • Nov 2021
          • 151
          • Brasil
          340k, on both pins.
          • JaroTech
            • Mar 2015
            • 351
            You have 0V on pin 3 (ON1), so UZ8 is not enabled for output at pins 13 and 14 (VOUT1). Measure the resistance to ground on pin 3.
            • BMCappelletti
              • Nov 2021
              • 151
              • Brasil
              you have 0v on pin 3 (on1), so uz8 is not enabled for output at pins 13 and 14 (vout1). Measure the resistance to ground on pin 3.
              93k.
              • JaroTech
                • Mar 2015
                • 351
                You should have the same resistance on pin 5.
                • BMCappelletti
                  • Nov 2021
                  • 151
                  • Brasil
                  A little higher. 99.3K.
                  • JaroTech
                    • Mar 2015
                    • 351
                    Sorry but it's bedtime for me, I'll continue tomorrow.
                    • BMCappelletti
                      • Nov 2021
                      • 151
                      • Brasil
                      Pin 5 is connected to RPE10 pin 4. And I have 3.3V on it.
                      Pin 3 is connected to RPE10 pin 3 and I have nothing on it.
                      • BMCappelletti
                        • Nov 2021
                        • 151
                        • Brasil
                        No problem.
                        Thanx.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Check resistance between pin 6 & 3 of RPE10. Should be 100K. If the resistance between these pins is fine, then you need to head towards SIO's basic requiremnts as A_ON comes from SIO. Remove UZ8 and see if you get voltage on pin3-This will give us an idea whether problem lies in +3.3V_M rail or not.
                          • BMCappelletti
                            • Nov 2021
                            • 151
                            • Brasil
                            91.4K. Would say it's fine? Should I proceed to remove UZ8 and check?
                            • mon2
                              • 14662
                              Yes, it is close to 100k and is fine.
                              • BMCappelletti
                                • Nov 2021
                                • 151
                                • Brasil
                                Removed it and now I have 3V on pin 3, on component RPE10.
                                • JaroTech
                                  • Mar 2015
                                  • 351
                                  Alright, so you found the short, UZ8 pin 3 is shorted to ground, you need to replace the chip. You have two options, you can replace with APE8990GN3B on page 38 or with TPS22966 on page 4, they are equivalent.
                                  • BMCappelletti
                                    • Nov 2021
                                    • 151
                                    • Brasil
                                    Could I replace it for a EM5209? I found it on an Acer board and this site says it has "similar description".
                                    https://www.alldatasheet.net/datashe.../EM5209VF.html
                                    • JaroTech
                                      • Mar 2015
                                      • 351
                                      The general description seems to be similar, you can try it.
                                      • BMCappelletti
                                        • Nov 2021
                                        • 151
                                        • Brasil
                                        Done it. Exact same readings.
                                        No voltage on pin 3, no voltage on BIOS. And lost the voltage that appeared on RPE after removing the other one.
                                          DELL Latitude E5450 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude E5450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5450 boardview and E5450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 08:40 PM
