Lenovo Legion Y520, not charging.
  • Crabolog
    • Apr 2022
    • 30
    • Ukraine
    Hi everyone, appreciate any advice on following:
    A laptop Lenovo Legion y520 came to me, not charging, AC led dark.
    I've changed two capacitors in the AC line which were shorted, and now it's working from AC and says that battery is charging, however battery % is not growing (been waiting a few hours).
    I'm not sure why, could anyone please advice what can I check?
    on JBATT1 connector:
    EC_SMB_DA1 = 3.2v
    EC_SMB_CK1 = 3.2v
    BATT+ signal only appears when battery is connected, and it's 10.47v which I assume is just coming from battery. Shouldn't it be 12v when battery is charging? And if yes, what can I check to identify why it is missing? If I check this signal without battery connected it's 0.6v and resistance to the gnd is 347kOhm
  • mon2
    • 14662
    Re: Lenovo Legion Y520, not charging.
    Battery charge profile can vary with the designer. Do not expect a fixed value here to be the same as others. Which charger IC is onboard? Post the topside markings.
    Perhaps the 'BQ' series from Texas Instruments?
    • Crabolog
      • Apr 2022
      • 30
      • Ukraine
      Bq24780s
      • mon2
        • 14662
        Attach the adapter and battery. Power up and carefully measure the voltage to ground of each pin on the charger IC.
        Post the readings and the pin numbers.
        • Crabolog
          • Apr 2022
          • 30
          • Ukraine
          PU201 PINS:
          1 ACIN = 19.78v
          2 ACP = 19.78v
          3 CMSRC = 20.46v
          4 ACDRV = 20.46v
          5 ACOK = 3.2v
          6 ACDET = 2.8v
          7 IADP = 0.079
          8 IDCHG = 0.008v
          9 PMON = 0.096v
          10 PROCHOT = 1.021v
          11SDA = 3.27v
          12 SCL = 3.27v
          13 CMPIN = 0.193v
          14 CMPOUT = 0.127v
          15 BATT_TEMP = 0.3v
          16 TB_STAT = 1.35v
          17 BATSRC = 11.37v
          18 BATDRV = 11.36v
          19 SRN = 11.37v
          20 SRP = 11.37v
          21 ILIM = 1.358v
          22 GND
          23 LODRV = 0v
          24 REGN = 6v
          25 BTST = 11.12v
          26 HIDRV = 11.37v
          27 PHASE = 11.38v
          28 VCC = 20.2v
          • mon2
            • 14662
            ACDRV is low and is not boosting to the required ~25v to enable the DCin mosfets.
            Locate the ~4k resistor on the ACDRV pin. Flux and carefully remove this part but do not lose it.
            Then power up again.
            Check the voltage of the ACDRV pin at the charger IC.
            Is it now ~25v ?
            Often the 2nd DCin mosfet gets damaged and causes such faults. Do review the above sticky by @Piernov on this topic.
            • Crabolog
              • Apr 2022
              • 30
              • Ukraine
              Can confirm ACDRV is now 25.56, laptop appears to be charging. So I should dig closer to PQ201 & PQ202 mosfets?
              • mon2
                • 14662
                If the ACDRV is boosted, the DCin mosfets should be enabled and charging the battery.
                If the battery charging fails, update this thread. Do test with a known good battery.
                • Crabolog
                  • Apr 2022
                  • 30
                  • Ukraine
                  I can confirm that battery is charging after I removed pr206 resistor from ACDRV line. But should I just leave it as it is? I assume something is still not good since I needed to remove this resistor?
                  • mon2
                    • 14662
                    If ACDRV has returned without PR206, this is a good sign for the charger IC.
                    However, without PR206, the gate voltage should not be enough on PQ201 & PQ202 to be enabled.
                    Confirm the voltage to ground of the gate pins being shared between PQ201 & PQ202 = pin # 4.
                    Being N-channel mosfets, the gate voltage must be higher than the voltage being passed between source / drain pins.
                    At this stage, suspect that you have a leaky mosfet @ PQ202.
                    Confirm this by removing all power -> meter in resistance mode.
                    Measure the resistance between the following pins on PQ202:
                    source (1-2-3) & drain (5-6-7-8)
                    source (1-2-3) & gate (4)
                    gate (4) & drain (5-6-7-8)
                    Post each measurement.
                    Often, the 2nd mosfet = PQ202 on your board, gets damaged and needs to be replaced.
                    In summary, you require ACDRV to be ~25v with PR206 installed. Given that ACDRV is lower once PR206 is installed implies you have a defective / leaky mosfet stopping this party.
                    • Crabolog
                      • Apr 2022
                      • 30
                      • Ukraine
                      Does 445 Ohm between source and gate means its shorted?
                      • mon2
                        • 14662
                        Yes!! Flux and remove this mosfet to check the same measurements when the mosfet is on your work table.
                        • Crabolog
                          • Apr 2022
                          • 30
                          • Ukraine
                          Issue resolved by replacing both PQ201 and PQ202. PQ201 was also damaged.
                          Big thanks for your help
                          • dune6170374
                            • Aug 2021
                            • 6
                            • FRANCE
                            Big big thanks mon2 ;-)
                            your explanations are just perfect
                              LENOVO Legion Y520 Legion i5-7400 Specification for Upgrade or Repair
                              This specification for the LENOVO Legion Y520 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y520 boardview and Legion Y520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                              09-12-2024, 02:30 PM
                              LENOVO Legion Y520 Legion i5-8400 Specification for Upgrade or Repair
