The motherboard turned on for 3 sec and automatically turned off. All inductor voltages are present in the ram module 1.35v, CPU core, 1.8v, 1.05v, 3.3v, and 5v stand-by. Ampere reading in the DC power supply when i turn on the board is 1st 16mA then to 110mA and then to 250mA, when the board is turned off it goes to 4mA all this happened in 3 sec. When the board is turned off only LDO is present at 4mA.
I plugged out the DC-regulated power supply and did some off-state checking to see any shorts in load switches and then primary and secondary power line regulators and MOSFETs.
After a while, I plugged in the DC power supply, and Suddenly ampere went to 300mA and settled at 110mA, the thing is, at this time no voltages were present except 5v and 3.3v standby, and 1.8v and 1.05v. Now the ram inductor shows 2.2ohms which shows the symptom as short. while the ampere reading is at 110mA in the standby state, no any voltages except LDO but the sandy IC TPS1285B is getting abnormal heat.
May I know what could have happened to the board while troubleshooting? I couldn't figure out
