asus tuf fx506ii DA0BKXMB8D0 REV D
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this please, I have here asus tuf FX506II DA0BKSMB8D0 REV laptop.The problem with this is no power, 20v is presents n Dc in mosfet and current sense resistor,but I noticed BQ24780S ic is warm here is the measurement of that ic.
    ACDET=2.7V
    ACOK=3.2V
    VCC=FROM 19.7V FLUCTUATE TO 19.6V
    ACDRV=26.3V
    REGN=6V
    HIDRV=FROM 8.4 DROP TO 6.4 THEN GOES TO 7.1 AND GOES TO 8.4 AGAIN
    PHASE=SAME VOLTAGE FLUCTUATE ON HIDRV
    LODRV=0.0074 FLUCTUATE TO 0.0064V
    ACP=0.0024V
    ACN=0.0024V
    Anyone can help this please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: asus tuf fx506ii DA0BKXMB8D0 REV D
    I found PC193 connected to SRP and SRN reads short in diode mode could it be this the problem?
    • mon2
      • 14220
      SRP and SRN will be bridged by a very low resistance resistor = current sense resistor. This will cause the meter to believe these pins are shorted. They are not shorted.
      The voltage readings for the charger IC look ok and the warm temp may also be ok.
      Review the 2 x DCin mosfets driven by the ACDRV pin. There will be a 4k resistor between ACDRV and the gate pins on the DCin mosfets of interest.
      Start with checking the main power rail -> remove all power -> check the resistance to ground of the main power rail. What is the resistance ? If it is low, there is a short on the main rail.
      Next, review the condition of these same DCin mosfets.
      Check the resistance across the mosfet pins.
      source (1-2-3) & drain (5-6-7-8)
      source (1-2-3) & gate (4)
      gate (4) & drain (5-6-7-8)
      Post each measurement. Often, the 2nd DCin mosfet starts to leak and causes the issues.
      • String2016
        • Nov 2015
        • 2238
        • philippines
        the first dc in mosfet measures S=5.2MEGAOHMS D=62K G=0L
        the second dc mosfet measures S=5.1MEGAOHMS D=24.3K G=0L
        BLACK PROBE TO GROUND
        and below
        firs dc in mosfet probe to black to source and red to drain= 0.600 megaohms
        and black to source and red to gate=0l
        and black to gate and red to drain=6.59megaohms
        second dc in mosfet probe to black to source and red to drain= 9.19 megaohms
        and black to gate and red to drain=6.6megaohms
        • String2016
          • Nov 2015
          • 2238
          • philippines
          I noticed that the 2 4k resistor connected to ACDRV pr205 and pr 206 measures only 2.3k
          • String2016
            • Nov 2015
            • 2238
            • philippines
            voltages of the two dcin mosfet are good both source have 20v and drain have 20v and gate both have 26v, current sense resistor measure 24.6k resistance.also noticed there is no 3v and 5v on coils and there is no standby voltage on bios chip
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              There is nothing wrong in the charging circuit. Move On to check basic requirements of SIO. 3V/5V may appear only after turning on. make sure keyboard is not faulty by shorting the power on pins manually.
