disable onboard ram lenovo ip3 nm-d151
  • Joandean14
    replied
    Originally posted by kamalkharbanda
    ON BOARD RAM DISABLE TESTED SOLUTION FOR NM-D151 MOTHER BOARD
    THANKS 100% WORKING TRY THIS
  • kamalkharbanda
    replied
  • degebe2006
    replied
    Originally posted by ktmmotocross
    Re: disable unboard ram lenovo ip3 nm-d151
    if somebody is strugling like me with resistors, this will show position of resistors for memory disable
    Thanks, I can disable the memory!!!!
  • degebe2006
    replied
    One resistor must be moved only.
    RC1606 (10K) ---> move it to RC1608 position. That's it.
    In RC1608, I have one resistor 10 Kohm, and RC1606 is 10 Kohm too. Thanks
  • degebe2006
    replied
    I have 4 gb onboard , move R1606 to RC123 and works? Thanks.
  • Deby
    replied
    This tutorial works 100%
    Like all the others who give the same instruction only in a different way.
    It doesn't take much to philosophize.
    With the BRD scheme and the brain, it is solved without problems.
    If the motherboard still doesn't work, then you have another problem.
    My board had symptoms of drawing around 750mA and climbing slightly as the CPU warms up.
    As soon as I failed with reprogramming the EC and Main bios, I went to disable the RAM memory.
    Immediately after the first startup of the motherboard, the current began to work variably and the image appeared without problems.
    So the instruction is checked and works.​
    replied
    Originally posted by Jan Svidek
    Notebook still not working, im using many Bios flies, but nothing happen.
    Now LCD still black, white light working, without battery using only 0,02A nothing is short and when Im plugin battery start charging normaly.
    Im lost....
    Post your bios in the "Bios requests ONLY!" forum and someone will take a look at it. You can try the RAM patcher for now https://www.badcaps.net/forum/troubl...63#post3172363
  • Jan Svidek
    replied
    Im lost....
  • Jan Svidek
    replied
    Originally posted by mon2
    Double check the strapping of each resistor. With no power, measure the resistance of each position. Compare with post # 26.
    Click image for larger version  Name:	dimm_only.png Views:	18 Size:	101.9 KB ID:	3276151
    I have everything as it is on post 26.
    It still doesn't work​
    maybe the BIOS is also damaged or? If somebody have BIOS pls upload, or Im try find in forum..
  • mon2
    replied
  • Jan Svidek
    replied
    I have this board:
    GV451&GV551 NM-D151
    Rev.: 1.0
    RAM on board its bad (Samsung)
    I moved RC1606 to RC1608 and nothing
    I added RC123 (2kohm - (serial 1+1k ohm)) and nothing
    maybe I need new bios ?
    LCD still black, without battery using 0,39A
    I searched the internet and here on the forum, but nothing works.
    can someone help please​
  • kyawthurabgo
    replied
    Thank Bro
  • ktmmotocross
    replied
  • Vesko356
    replied
    I moved only R1606 to RC123
    Will work but R1606 is 10K and RC123 should be 2K, so the proper way to do it in your case is: R1606 must be removed out, and 2K resistor to be added in a RC123 position!
  • kamalkharbanda
    replied
    in my case i have 8gb samsung onboard ram on my motherboard.
    R1612 , R1610 , R1608 , R1606 resistances originally placed.
    RC123 originally blank.
    I moved only R1606 to RC123 and display successfully done on ext. dimm.
    and onboard ram permanently disabled. No need pull onboard ram chip.
    May be helpful for others
  • Vesko356
    replied
    Originally posted by makx1998
    Do you need to physically remove the memory chips? flash bios?
    No.
  • makx1998
    replied
    And 2K resistor must be placed at RC123 position.
  • Vesko356
    replied
  • LKB
    replied
  • Vesko356
    replied
