I have a Dell Latitude 7480. During POST it complains that the TPM device is missing. I've tried various ways to get the TPM device to be present at POST, after which you can flash the correct TPM firmware, but none have worked so I thought I'd investigate if the TPM chip is working. Seems there can be a mismatch of UEFI firmware and TPM firmware which causes it to not work but I've read that the TPM chip can fail too. I realize the laptop itself isn't worth a lot. Still I'd like to investigate to learn more.
I found the heat pipe for the CPU cooler runs over the area of the TPM chip blocking access to the chip, and nearby capacitors and resistors. I think I've seen some repair videos where the repairer plugged in the laptop motherboard and switched it on without the cooling system in place. Though, I hesitate to try that. I've always thought it wasn't good to run a CPU without a cooling system. Maybe that isn't as black and white as I thought? What do you do when the cooling system is in the way of doing a board level repair and you need to power the board to check voltages? I'm guessing I need to switch on the board, rather than only plug in the board, to see if the correct voltages are being delivered to the TPM chip. Any advice?
