Re: Acer Swift SF314-54 charging, not powering up
I'm just thinking if my BIOS or CPU is bad. No more interest to find fault if there is something bigger going on.
I'm not an expert about reading those sequence things. If I'm reading something wrong there might be days of work with no sense. Laptop will be binned soon.
Big thanks to everybody who tried to help with this thing.
have you check all sqence? pg 102
where you've stuck?Leave a comment:
any update? i've same situation here. rtcrst_on 0v.. but rtcrst# have 3.3v. mine are sf314-56g but smiliar.Leave a comment:
Could my CPU be shorted/bad? Or bios chip?Leave a comment:
I see, voltages are fine. Keep digging.Leave a comment:
I don't have the intention to make the confusion here complete but imho there is a display issue in the schematics page of the EC and RTCRST_ON is actually Pin107 instead of 106...
From this assumption Pin 106 should be SYS_PWROK. Continuity check between EC Pin 107 and Q1701 Gate will clarify.
13 ohms..
0.017V with diode measurementLast edited by kuupotin; 02-11-2023, 06:41 AM.Leave a comment:
From this assumption Pin 106 should be SYS_PWROK. Continuity check between EC Pin 107 and Q1701 Gate will clarify.Leave a comment:
From this assumption Pin 106 should be SYS_PWROK. Continuity check between EC Pin 107 and Q1701 Gate will clarify.Last edited by Sephir0th; 02-09-2023, 05:06 PM.Leave a comment:
Made a new one. 3.240V and 3.238V..
There is some coil whine when battery or charger attached. Whine stops and starts after a while when pressing reset button on mobo sub board.Last edited by kuupotin; 02-09-2023, 11:45 AM.Leave a comment:
You likely have no problem in RTC circuit. perhaps you measured the resistance with adapter connected or immediately after mb was powered. resistance should always be measured with no power and if power is apllied, then one should wait for atlest 2-3 mins to let it discharge.Leave a comment:
Cmos battery new. After connecting to mobo, only very slight drop in voltage. I'll measure it later today.Leave a comment:
Give me 2 measurements of the CMOS battery like this:
V when outside the circuit. V when inside the circuit of the CMOS battery.Leave a comment:
Voltage injection shold be in forward way only-thats black to gnd and red to the target point. Now i'm confused a bit. Black probe to gnd and red to Q1701 Gate measures 2 Ohms as per you and thats a dead short but voltage injection is not taking any current amps-Thats strange. Something is seriously wrong here in RTC circuit. Look for all the caps connected to RTC and try to remove them one by one-just desolder and put them on 1 pad only so that you dont loose them. You can get all the caps connected to RTC rail by searching RTC in schematics and check all the points where it takes you.
cheesh....
EDIT: and now its infinity. What the .. is going on?Last edited by kuupotin; 02-08-2023, 09:22 AM.Leave a comment:
Voltage injection shold be in forward way only-thats black to gnd and red to the target point. Now i'm confused a bit. Black probe to gnd and red to Q1701 Gate measures 2 Ohms as per you and thats a dead short but voltage injection is not taking any current amps-Thats strange. Something is seriously wrong here in RTC circuit. Look for all the caps connected to RTC and try to remove them one by one-just desolder and put them on 1 pad only so that you dont loose them. You can get all the caps connected to RTC rail by searching RTC in schematics and check all the points where it takes you.Leave a comment:
Measurement at post#42 are all good except Q1701 Gate. Your PCH seems ok so far. You can try removing the SIO and see if resistance on Q1701 Gate climbs up significantly. If you have the tools and skills, you can just lift the RTCRST pin of KBC to confirm this but be carefull as it require good skill.
Another option is to remove Q1701 and inject voltage on gate to see if anything gets hot. Dont inject more then 1V.
Removed q1701 and measured resistance again. When positive probe on gate there is only 2 ohms, but when reversed probes, it shows 460 ohms.
Tried inject 1V to gate, positive on gate, there was no current. Backwards it took 50mA. WTH...Leave a comment:
Another option is to remove Q1701 and inject voltage on gate to see if anything gets hot. Dont inject more then 1V.Leave a comment:
As @mon2 has highlighted, it seems something wrong in RTC circuit. I'll suggest to check these first before jumping on the conclusion of defective KBC. I've never seen a bad EC pulling down RTC circuit. If thats the case here, it'll be rare instance. My doubt goes to PCH instead.
01.Resistance on Q1701-All pins
02.Resistance on G1701 pin2.
If resistance on G1701 jumper,pin2 is low, you are very likely staring at a shorted RTC section of PCH. If you are lucky, it could be a shorted cap on RTC lines.
Q1701:
gate 620 ohm
drain infinite
source infinite
G1701:
pin2 infinite
pin1 ground?Leave a comment:
Please note my post#23 for all the newbies here. One wrong step in a hurry may make the board unrepairable. So have patience in diagnosing properly and dont play with voltage injection at the drop of hat. The new gen SOC's wont give you a second chance to fix it.Leave a comment:
This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:00 AM
This specification for the Acer Swift Swift X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift X boardview and Swift X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Swift...09-07-2024, 02:20 AM
This specification for the Acer Swift Swift 1 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 boardview and Swift 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Swift Swift...09-07-2024, 05:00 AM
This specification for the Acer Swift SF114-34-P5YB + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P5YB + Pack Gold Acer 14'' boardview and SF114-34-P5YB + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-07-2024, 03:10 AM
This specification for the Acer Swift SF314-43-R9W7 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-43-R9W7 + Pack Gold Acer 14'' boardview and SF314-43-R9W7 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-07-2024, 03:10 AM
- Loading...
