Acer Aspire VN7-591G-79RH No power, no charging after battery replacement
  • Mixeris
    • Jan 2023
    • 7
    • Latvia
    Had this laptop for while, old battery was almost completly dead. Ordered new Green Cell AC54(AC14A8L-3S1P)battery.
    After installing new battery:
    No turning on from battery
    No turning on from power adapter
    No indicator leds
    Checked voltage on DC jack: 18.6V
    Checked voltage on battery terminals: 10.1V
    So I removed main board.
    Checked for short circuits between : AD+ and ground, DCBATOUT and ground.
    Checked voltages:
    AD+ :18.6V
    DCBATOUT:18.6V
    3D3V_AUX_S5: 3.3V
    5V_AUX_S5: 5.0V
    As I understand these are responsible for powering KBC.
    As I see in schematics battery, charger circuit and KBC(NPCE285PA0DX-GP) is connected via I2C. Unfortunately don't have access to ociloscope.
    Have no idea how to move forward, but should I suspect KBC?
  • Sephir0th
    • Oct 2020
    • 1282
    Re: Acer Aspire VN7-591G-79RH No power, no charging after battery replacement
    I'd start with removing the "new" battery to see whether the device can come on. Also CMOS hard reset strongly advised. If already done, please tell so.
    Otherwise proceed with PU4501. Remove all power and set multimeter to Ohms mode, range 200. Resistance to GND of pin 3 and pin 13 please.
    FairRepair on YouTube
    • Mixeris
      • Jan 2023
      • 7
      • Latvia
      Thank you for reply!
      Board with removed battery have same symptoms.
      Also removed RTC battery and did hard CMOS reset.
      Resistances for PU4501(TPS51225)
      Pin3 - GND 6.48kOhm
      Pin13 -GND 32.3kOhm
      • mon2
        • Dec 2019
        • 14238
        The AUX rails are working so the resistance to ground for each are expected to be ok.
        What are the voltage to ground readings of the following?
        Pin 6 (ACDET)
        Pin 5 (ACOK#)
        Pin 16 (REG)
        On charger IC pu4403 ?
        PWR_3D3V_EN
        PWR_5V_EN
        3D3V_PWR
        5V_PWR
        On pu4501.
        • Mixeris
          • Jan 2023
          • 7
          • Latvia
          Voltages on PU4403
          Pin 6 (ACDET)-2.56V
          Pin 5 (ACOK#)-3.28V
          Pin 16 (REG)-5.96V
          PU4501
          PWR_3D3V_EN - 3.24V
          PWR_5V_EN - 3.24V
          3D3V_PWR - 3.36V
          5V_PWR - 5.10V
          • mon2
            • Dec 2019
            • 14238
            What are the topside markings on the charger IC @ PU4403 ?
            From the pin symbol, ACOK# = active LOW signal.
            If this line is LOW, the AC adapter is OK. Your status is high.
            • Mixeris
              • Jan 2023
              • 7
              • Latvia
              Checked again Pin 5(ACOK#)@PU4403 - 0.00V (last time measured wrong spot)
              Markings on PU4403 are :
              BQ737
              TI 47i
              • mon2
                • Dec 2019
                • 14238
                Ok. Good to know. Schematic has some house marking.
                Quick tests for I2C / SMBUS, check the voltage to ground of:
                SCL
                SDA
                lines with the power adapter connected. Each should be a default logic high value since these are open-drain pins and the local pull-up is used for the soft high status.
                If not, remove all power -> measure their resistance to ground.
                Also, can check in DIODE mode on the meter:
                RED meter lead, yes RED to GROUND.
                Black meter lead to point to test.
                • Mixeris
                  • Jan 2023
                  • 7
                  • Latvia
                  BAT_SCL an BAT_SDA lines are 3.3V
                  Diode test is 0.456V for both lines.
                    • 20966
                    Find the switch RESET1 SW-TACT-124-GP ,BAT_G
                    • Mixeris
                      • Jan 2023
                      • 7
                      • Latvia
                      Checked the RESET1 switch, it is working.
                      This laptop has hole in the back to press this switch with needle, so I understand it is NO.
                        ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-12-2024, 03:28 PM
                        ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-12-2024, 02:30 PM
                        ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
