HP Pavilion x360 14m-dh0000 no power
Re: HP Pavilion x360 14m-dh0000 no power
Got it - thanks. That is an ESD diode array.
To confirm, if D4301 is REMOVED, then ED4302 is not heating up?
But diode D4301 measure to be ok on your work table?
In diode mode, it should conduct in one direction with readings like 0.4 to 0.6 but OL in the opposite direction. Can you confirm it?Comment
the diode was heated at the moment when I injected 2 v into the resistor r4503. I believe that you get hot because of ED4302. .. i measure diode and it iis o.140Last edited by arber1232; 01-12-2023, 10:56 AM.Comment
The LDO rail has a max current rating. If the current rating (ie. downstream load) is exceeded, the voltage will drop.
Much like us lifting weights (although have pulled my back recently), you have limits. If you try to lift too much, you can only lift a smaller amount.
So this means, this power rail still is faced with a larger than expected load.
There is a possibility that this regulator is defective but not sure of this status, yet.
Does the LDO heat up ?Comment
ldo ? i not understand . ic not heatThe LDO rail has a max current rating. If the current rating (ie. downstream load) is exceeded, the voltage will drop.
can we say kbc is problem ?Last edited by arber1232; 01-12-2023, 12:39 PM.Comment
It could be. Not a KBC expert. Wait on others to comment but yes, who ever is on this power rail is pulling it down and exceeding the max current rating for this LDO rail of the regulator.
That is, someone is out of spec. Is the KBC getting warm ?
If you feel comfortable, remove the series resistor on this LDO to remove the pin 17 from the load.
Then use your external power supply @ 3v3 setting and apply to the downstream load. This is because your external power supply can offer higher current.
What is the current draw on your external power supply?
Is anyone heating up ? Perhaps the KBC ?
Do wait on others to comment but as noted, someone on this leg of the circuit is not consuming the correct current so the power rail is being pulled down.Comment
i try with power supply but current in power supply is 0.030 ah and kbc or other component not heatIt could be. Not a KBC expert. Wait on others to comment but yes, who ever is on this power rail is pulling it down and exceeding the max current rating for this LDO rail of the regulator.
Not resistance.Measure the voltage to ground of each pin on PU4401 mosfet.
Meter in DC volts (30v or higher is ok). Then red meter probe on pin to test. Black meter probe to ground.
For this mosfet (N-channel) to turn ON, the GATE pin #4 should be ~25 volts.Comment
Ok. Very possible that this mosfet is defective or something on the load side is shorted.
Remove all power.
Meter in RESISTANCE mode.
Check the resistance across the mosfet pins as follows:
source (1-2-3) & drain (5-6-7-8)
source (1-2-3) & gate (4)
gate (4) & drain (5-6-7-8)
Post each measurement. If any of these checks are with a low resistance, the mosfet is defective and should be replaced.Comment
This specification for the HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 14-dh1000na boardview and Pavilion x360 - 14-dh1000na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-06-2024, 03:30 PM
This specification for the HP Pavilion x360 Pavilion x360 - 15-dq1004na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 15-dq1004na boardview and Pavilion x360 - 15-dq1004na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-06-2024, 12:18 PM
This specification for the HP Pavilion x360 Pavilion x360 - 14-cd0007na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 14-cd0007na boardview and Pavilion x360 - 14-cd0007na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-06-2024, 09:37 AM
This specification for the HP Pavilion x360 Pavilion x360 Convertible Laptop PC 14-dh0500sa Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 Convertible Laptop PC 14-dh0500sa boardview and Pavilion x360 Convertible Laptop PC 14-dh0500sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-06-2024, 09:23 AM
This specification for the HP Pavilion x360 Pavilion x360 Convertible Laptop PC 14-dh0500na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 Convertible Laptop PC 14-dh0500na boardview and Pavilion x360 Convertible Laptop PC 14-dh0500na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-06-2024, 09:23 AM
- Loading...
