Why is this display dim and whining?
    Re: Why is this display dim and whining?
    I see it, not sure how to interpret it though.....
    The majority of the pins on the regulator measure 12V, there's a trace from the lower right pad to a diode, the other side of the diode measures ~30V.
    Interestingly enough, on the good board that diode measures 38V.
    Look for the glob of solder to see where I'm talking about, the corrosion broke the trace so I did the best I could with one hand....
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
      Bump, any ideas bud?
      -retiredcaps
