Dell optiplex 3000 micro bios
  • tlkdgb
    replied
    Hello, my BIOS is all "LOCKT" Can you please help me unlock the bios?
    any idea to fix this ?
    OptiPlex 3000 Micro
    Service Tag: 1119MP3
  • redcapangler
    replied
    Originally posted by redcapangler View Post
    I tried this and it did not work. I'm trying another bios from this thread for the 16mb to see if that one will work. Really stuck here.
    Did not work, posting my original files to see if someone else can assist? I'm looking to have absolute disabled in both of these files / cleaned ME please.
    Service tag is JXHJ5S3
    I've been struggling for about a month in this thread trying to get this fixed, any help is truly appreciated.
    - Brian
  • redcapangler
    replied
    Is it possible I could just load the bios from this older post to resolve my issue? Or would that not work?
    Thank you,
    - Brian
  • redcapangler
    replied
    Originally posted by hoaca388 View Post
    Re: Dell optiplex 3000 micro
    1111111
    Thank you,
    - Brian
  • redcapangler
    replied
    Originally posted by volinakis View Post
    well, 1st time when you wrote the file I sent you, you said it wasn't work. 2nd time when you wrote it in bios chipset it worked ... so, where was the problem? 32Mb chipset contain Bios_Region so Computrace is in it, no need to modify 16Mb chipset usually but you seem to have also problems with ME firmware. So you need to do a clean ME to your full bios.
Name:	Screen Shot 2025-04-02 at 20.30.23.png
    Hi volinakis , I was unsuccessful and got stuck. I was able to install ME Analyzer, get the same output in you screenshot at the bottom when loading my 16mb file. When I go to find the right firmware (attached in screenshot), I does not seem that my version is available out there to use as a base file for the cleaning process. Do you know of anyone that has gotten their ME Cleaned with version 16.1.31.xxxx? I'm only seeing all the guides go up to version 15.x.x.
    Any help is appreciated, I'm really stuck on this next part.
    Thank you,
    - Brian.
  • Imdeksn99
    replied
    Originally posted by peste View Post
    post full name and model, motherboard model, etc.
    DELL OPTIPLEX 3000 micro PC
  • peste
    replied
    Originally posted by Imdeksn99 View Post
    guys please help me to remove admin password on bios
    st: 4TJ0HY3
  • peste
    commented on 's reply
    post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
    read the forum rules..
  • Imdeksn99
    replied
    st: 4TJ0HY3
    https://www.badcaps.net/forum/troubl...30#post1622430
    https://www.badcaps.net/forum/troubl...l-8fc8-patcher
  • pronto
    replied
    I NEED UNLOCK PASSWORD
    OPTİPLEX 3000 MICRO
    ST:8XWK4V3
    REG MODEL D15U
  • redcapangler
    replied
    I will try to do this myself and report back. First time performing an "ME" clean.
  • volinakis
    replied
    Hi - so i've verified soldering is not the issue (have successfully reflashed many times on this board now). I did remove the CMOS battery before soldering, no issues there. Chip is working.
    On a similar board (Optiplex 7010 micro) I required both the 16mb and 32mb chips to be updated in order for it work. hoaca388 helped with that one. I'm wondering if edits need to be made to the 16mb file as well?
  • redcapangler
    replied
    so it was about poor soldering... did you remove CMOS battery before soldering bios chipset? Try applying defaults and see if works.
  • volinakis
    replied
    Ok, I reflashed original bios again, confirmed the machine can still boot (success) cleared the settings - then reflashed the updated file you provided.
    The video came online (good, I wasn't waiting long enough for the reboots), i went into bios but the Absolute is still grayed out. Any thoughts?
  • redcapangler
    replied
    I only invalidated Absolute entry, has nothing to do with video output. you have to wait for 2-3 minutes, machine will restart several times with no image. I just did a 5440 making same modifications and it worked.
    Click image for larger version  Name:	IMG_2395.jpg Views:	0 Size:	2.08 MB ID:	3606039
  • volinakis
    replied
    volinakis - Did not work. Any ideas? Thank you for all your help.
  • redcapangler
    replied
  • volinakis
    replied
    volinakis - For some reason i'm no longer receiving video output (can't get back to bios). Tried both the HDMI and Display port. Any idea? I confirmed it was written correctly to the chip already (verified hex readback).
    check soldering
  • redcapangler
    replied
    volinakis - I was able to flash the original bios back and boot up. I'm trying to factory reset, then reflash to see if it helps it boot up.
