Looking for Circuit Diagram for AMD Radeon R9 295X2
  • Carouselambra21
    • Jun 2022
    • 3
    Hi, I work on Computers, and boards at home for some friends, one of my friends was having problems with his GPU, so I took a look at it. It looks like a transistor is blown on it, I'm wondering if it's at all fixable, and if a regular soldering iron would be able to do it, for it's a surface mounted component.
    Thank You.
    I've tried contacting The vendor, PowerColor, which told me they just slap there name on it and sell it. That I should contact AMD for it's there Tech. I was then told by AMD to contact PowerColor about a Circuit Diagram, I told them, what they said. Then I was told contact one of the distribution people to sign a NDA to get a Diagram? At that point I gave up. I saw this wonderful forum, in hopes someone here might have some advice, or even the diagram for this card.
    Thank You - Jacob
  • gt403cyl
    • Jan 2017
    • 35
    Re: Looking for Circuit Diagram for AMD Radeon R9 295X2
    looks like a capacitor is blown....
    • Carouselambra21
      • Jun 2022
      • 3
      Ah yes capacitor not transistor lol
        AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
        The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
        10-01-2024, 12:46 PM
        AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
        The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
        10-01-2024, 01:07 PM
        AMD Radeon RX 470 / RX 580 Schematic & Board View
        The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
        10-01-2024, 12:52 PM
      • klebendes_etwas
        Search for: QSC K10.2 Circuit Diagram & Component Layout Overview
        by klebendes_etwas
        Hello everyone! :-)
        An acquaintance of mine works as a DJ in his spare time and brought me a defective QSC active loudspeaker (Model: K10.2) for repair.
        Error description: The device could not be switched on (after he lent it to another DJ).
        A visual inspection revealed an obviously blown fuse (F41) and a cracked thermistor (R41) on the mains filter board. A closer look at the amplifier board revealed two defective power MOSFETS (Q13, Q14) and other defective components on the +12VLOW rail.
        After replacing all the obviously defective components, the...
        09-21-2024, 04:00 PM
        AMD Radeon R7 340 / R7 430 Schematic & Board View
        The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
        10-01-2024, 12:36 PM
