NUC5i3MYBE or MYHE
  • Prol
    Mr
    • Jan 2022
    • Portugal
    NUC5i3MYBE or MYHE
    I bricked my Bios (can´t help myself for not messing around with stuff) and forgot to make backup and cannot recover
    if anyone has a backup I would be very grateful
    Thank you in advance
  • Shadowtuy
    Bricked bios from a bad flash/update in a case of NO BACKUP repair question
    by Shadowtuy
    So I'm new here and have successfully unlocked a bios using "RCUnlocker" but after that I'm curious on recovery of a bricked bios from a bad flash/update in a case of NO BACKUP.
    The part I'm stuck on is my HP backup are a 32,768KB and 16,384KB image compared to a fresh bios from HP at 23,690KB. How would I use the fresh image to repair a flash chip? The guide I'm following just takes the image and flashes it over but clearly there is more to it.
    Just looking to expand my knowledge of this since the password removal worked great. Sorry if I missed this being...
    09-05-2023, 11:24 AM
  • Daniel Valdez
    Samsung UN70RU7100K halfway bricked after messing with service menu
    by Daniel Valdez
    Dear All,
    FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
    12-06-2024, 06:56 PM
  • ChaosLegionnaire
    bricked my laptop ram from messing around too much with spdtool!
    by ChaosLegionnaire
    so i thought i could squeeze some extra speed out of my ram... i was trying it using some 2x2gb kingston hyperx so-dimm ddr2-667mhz cl4 on my dell latitude e6500 latoptop. it worked well only until when i tried flashing the modified settings on it using spdtool. laptop now beeps for bad ram... *grumble* had to add the stock 2x2gb nanya ddr2-800mhz cl6 ram back into it...
    i tried putting one hyperx module in and the other nanya module in thinking it would follow the nanya's looser timings and settings but nooo... still no boot and same old bad memory...
    11-20-2021, 06:32 AM
    APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
    by sam_sam_sam
    This started a few days ago and does this about every 8 hours
    After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
    The battery backup is about 3 or 4 years old
    Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
    06-02-2024, 02:30 AM
  • Chris_stand
    Clevo PD50PNN won't boot after BIOS Backup
    by Chris_stand
    i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
    At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
    Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
    But the...
    04-28-2023, 03:08 PM
