Graphics card Schematics and Boardviews
This is a sticky topic.
  • Rezistor
    • Jun 2021
    • 302
    • USSR
    #321
    Re: Graphics card Schematics and Boardviews
    Originally posted by poprom1965
    schematics GigabyteN760 OC-4GD please
    https://smd.db-x7.ru/search/?q=GV-N760OC
    • Rezistor
      • Jun 2021
      • 302
      • USSR
      #322
      Originally posted by coco666
      Hello
      Could some one help me???, i'm looking for the shematics and Boardview for the Radeon RX 5700XT
      https://smd.db-x7.ru/search/?q=GV-R57XTGAMING
      • SagiT
        • Jun 2021
        • 7
        I´ve got a gigybyte GTX780Ti OC and need the Boardview please.
        • WayOfTheRoad
          • Aug 2021
          • 59
          Does anyone have a boardview for a Zotac GTX 1070 Amp Edition? Thanks!
          • Rezistor
            • Jun 2021
            • 302
            • USSR
            #325
            https://smd.db-x7.ru/search/?q=GV-N780OC
            • ctanto333
              • Nov 2021
              • 5
              • India
              #326
              Please I need a board view for Radeon RX 460.
              • Rezistor
                • Jun 2021
                • 302
                • USSR
                #327
                https://smd.db-x7.ru/load/boardview_...-11200?aAnmfcw
                • ctanto333
                  • Nov 2021
                  • 5
                  • India
                  #328
                  I Need Board view for MSI RX460.
                  • SagiT
                    • Jun 2021
                    • 7
                    Originally posted by Rezistor
                    Thx but thats a non Ti. I need the Ti in cause of the 2 8Pin Pex Connectors.
                    • jobguitar
                      • Nov 2021
                      • mexico
                      #330
                      Originally posted by Chickenhawk
                      Hi, I'm looking for Boardview for ASUS GTX 1070 Dual (not the Strix) # CG411A. Thanks!
                      https://drive.google.com/file/d/10C5...ew?usp=sharing
                      • jobguitar
                        • Nov 2021
                        • mexico
                        #331
                        its similar
                        • jobguitar
                          • Nov 2021
                          • mexico
                          #332
                          hi this is boardview ASUS DUAL GeForce GTX 1060 OC 6GB DUAL-GTX1060-O6G CG410PLM 1.01
                          https://drive.google.com/file/d/10C5...CMItPss3v/view
                          • xpepsi2008x
                            • Oct 2021
                            hi does anyone have a board view or pdf for gigabyte gv-n1080wf3oc-8gd or know if the 1070 wf2 is the exact same trying to figure out 2 componuts on the board located at R990 and R991 if theyre resistors or not and values any help would be apperciated thank you
                            • WayOfTheRoad
                              • Aug 2021
                              • 59
                              I've found out that they're all pretty much the same. You just have to find the same sections on each variation of 10-series.
                              So the 1.8v, 5v, etc tend to use the same parts and components but may have them in different spots on each make of card. So, your parts will likely be on any other 1070 boardview you can find but you just have to find them (by pattern or location).
                              I just wouldn't use a 1070ti or the like. If you have a normal 1070, use another normal 1070 boardview.
                              Also, there are outright schematics for a 1070 on here and that may also help you if you can identify what rail those components you need are on. Good luck!
                              • DetectiveStrawberry
                                • Nov 2021
                                • Italy
                                #335
                                Hello everyone.
                                I'm looking for Gigabyte GTX 980Ti (GV-N98TG1 GAMING-6GD) Schematics, as I'm trying to fix a blown Mosfet & Capacitors at the bottom right side of the card.
                                Thank you all very much in advance.
                                • WayOfTheRoad
                                  • Aug 2021
                                  • 59
                                  Originally posted by DetectiveStrawberry
                                  Hello everyone.
                                  Hello! IIRC, most 980ti cards are similar across manufacturers. Similar parts and designs with some slight variations in placement. There is one on page 13 for another manufacturer so check that out.
                                  Also, if you find one for a TitanX card they're identical.
                                  PS: I recently fixed an EVGA 980ti SC 6GB. In may be able to help you if you DM me a photo of the cap and mosfets issue in question. I even have a few of the mosfets left over to possibly test on if it's an issue with that.
                                  • mattkpo077
                                    • Jul 2021
                                    • Argentina
                                    #337
                                    Hello everyone, I am looking for the schematic of an Asus gtx 1650, I have to find a replacement for an Ic, which only says "53C3" is of the SOT-23-5 type, but I don't know what it is, if someone can help me . Greetings
                                    • ctanto333
                                      • Nov 2021
                                      • 5
                                      • India
                                      #338
                                      • Rezistor
                                        • Jun 2021
                                        • 302
                                        • USSR
                                        #339
                                        MSI MS-V3xx ??? Rev xx ???
                                        • xpepsi2008x
                                          • Oct 2021
                                          Thank you, ive got a few differnt board views and schematics here my problem is board view is showing something that looks like maybe a ferite bead then on the pdf ones i have its showing resistors a 10k and a 0ohm this is a little confusing here is a picture of what they actually look like on the gigabye 1080 board i have one is located at r990 and the other is r991
                                            Lenovo ThinkPad P53 Mobile workstation P Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad P53 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P53 boardview and P53 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 09:53 AM
                                            Lenovo ThinkPad P73 Mobile workstation P Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad P73 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P73 boardview and P73 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 09:45 AM
