Schematics of GA-EP41T-USB3
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Dear forum members,
    I need the schematics file of Gigabyte mainboard GA-EP41T-USB3.
    The schematics of any other mainboard in this series (GA-EP41T) would be useful.
    thanks
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Schematics of GA-EP41T-USB3
    http://sualaptop365.edu.vn/threads/s...-doi-41.12375/
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      thank you.
      Let us consider a CPU_vcore circuit that has 3 PWM lines (or phases). What will be happen if I disable one line (by removing its components) such that the other two lines provide voltage for the CPU?
      I mean: will be there any shortage of current or voltage for the CPU?
      will the CPU_vcore circuit fail after a while of working?
      • piernov
        • Jan 2016
        • 4435
        • France
        Multiple phases are meant to share the current to prevent excessive loss and overheating. You shouldn't run a buck converter with less phases than it was designed for. It'll indeed end up overheating and killing the other phases when under load (which may kill a high side MOSFET, sending 12V to the CPU and killing it as well). It could work if you use a lower powered CPU but I wouldn't recommend it anyway.
        Also depending on the layout this will prevent the buck converter from working at all.
