Dell Optiplex 7010 D13_MFF_LUXOR_LOW 212045-1 bios
  • peste
    • 13283
    • ROMANIA
    Dell Optiplex 7010 bios OK
    Motherboard D13_MFF_LUXOR_LOW
    212045-1
  • EthanMai
    • Jul 2020
    • 103
    • 美国
    I flashed the main BIOS and EC BIOS at the same time, and the white light flashed.
    • egelaptop
      • Jun 2015
      • 124
      • türkiye
      unfortunately I couldn't get a picture
      • xpy000
        • Feb 2022
        • 16
        • Morocco
        hi every one. Please I need your help with this locked bios dump. Model: Optiplex micro 7010. ST: 8ZJGH24 MB: d13_mff_luxor_low 212045-1 Reg Model: D15u Reg Type: D15U004
          SMDFlea commented
          Editing a comment
          Thread merged.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12207
        Unlocked
        • xpy000
          • Feb 2022
          • 16
          • Morocco
          Thanks a lot it worked. Can you please help with this one too. I will be very grateful. Model: Optiplex micro 7010. ST: 54DKWZ3 MB: d13_mff_luxor_low 212045-1 Reg Model: D15u Reg Type: D15U004
          • hoaca388
            Badcaps
            • Jan 2022
            • 12207
            Unlocked
            • xpy000
              • Feb 2022
              • 16
              • Morocco
              Thank you it worked
              • xpy000
                • Feb 2022
                • 16
                • Morocco
                Hello guys. If you can help me with this corrupted bios dump file. I dumped it from the bios chip to unlock the password but when I flashed it again, the computer flashes amber light 3 times and white light 6 times, an indication of a bad bios file. I checked the file, it is original because I could see the original Service Tag number in it but for some reason the computer won't work. here is the info. Model: Optiplex micro 7010. ST: FXJGH24 MB: d13_mff_luxor_low 212045-1 Reg Model: D15u Reg Type: D15U004.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12207
                  Unlocked
                  • xpy000
                    • Feb 2022
                    • 16
                    • Morocco
                    Thanks for your help. I am still getting a corrupted bios file error. Is there anyway to fix this file? As I said it is original but seems to be missing something. I would be very grateful for your help
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12207
                      Try
                      • xpy000
                        • Feb 2022
                        • 16
                        • Morocco
                        Thanks for your help. I really appreciate it. I flashed the attached file. The amber light is gone but I am not getting any image, only continuous restarts with the fan blasting full speed and white light.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12207
                          Flash again with the original file (lock file) to see if it can be posted? If it can't be posted, you have accidentally damaged the hardware
                          • xpy000
                            • Feb 2022
                            • 16
                            • Morocco
                            appreciate your help my friend. I am sure that it is not a hardware issue because I had the same issue with another similar computer. The only difference is that I made three dump files as backup so when I flashed the corrupted one I got the 3 amber 6 white issue but I just flashed the second bios file and the problem was solved. As for this one, I made only one. The problem seems to be with the programmer I am using. Sometimes the dump file is corrupted while dumping it from the chip. Anyway I really appreciate your time and concern. I will try to find a way to fix it somehow.
                            • okt19844
                              • Apr 2019
                              • Türkiye
                              st:3522y14 I would appreciate it if you could reset the password.
                              • RIGHT TEMP
                                • Oct 2024
                                • SRI LANKA
                                Hello guys. If you can help me with this corrupted bios dump file.The computer flashes amber light 3 times and white light 6 times, an indication of a bad bios file. I checked the file, it is original because I could see the original Service Tag number in it but for some reason the computer won't work. here is the info. Model: Optiplex micro 7010. S/T 8C7YPW3
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12207
                                  Unlocked
                                  • RIGHT TEMP
                                    • Oct 2024
                                    • SRI LANKA
                                    Hello guys. If you can help me with this corrupted bios dump file.The computer flashes amber light 3 times and white light 6 times, an indication of a bad bios file. I checked the file, it is original because I could see the original Service Tag number in it but for some reason the computer won't work. here is the info. Model: Optiplex micro 7010. S/T 8C7YPW3​ reg modle d14u reg type d15u004 optiplexmicro 7010
                                    • RIGHT TEMP
                                      • Oct 2024
                                      • SRI LANKA
                                      Hello guys. If you can help me with this corrupted bios dump file.The computer flashes amber light 3 times and white light 6 times, an indication of a bad bios file. I checked the file, it is original because I could see the original Service Tag number in it but for some reason the computer won't work. here is the info. Model: Optiplex micro 7010. S/T 8C7YPW3 reg modle d14u reg type d15u004 optiplexmicro 7010​
                                        DELL OptiPlex 7010 OptiPlex 7000 i5-3470 Specification for Upgrade or Repair
                                        This specification for the DELL OptiPlex 7010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7010 boardview and OptiPlex 7010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                        09-12-2024, 02:20 PM
