Repopulating SATA ports -- HP 800 G2 SFF.
  • ipmungam
    • Nov 2021
    • 8
    Hi All,
    I have a HP Elitedesk 800 G2 Small Form Factor (SFF). Apparently it is the same motherboard as the Tower (TWR) version, and their BIOSes looks to be identical. The TWR supports up to 5 SATA connections, the SFF only 3 -- and indeed there are 2 unpopulated SATA port pads on my SFF motherboard. I'd like to get these working.
    I removed two SATA port connectors from a scrap board and soldered them to the empty pads on my motherboard (once again, dicky96's YouTubes were very helpful, thanks). It went pretty well, connections look good, however the BIOS still only detects 3 SATA ports.
    I am wondering if there are more components necessary, e.g. some resistors or some such, that also need to get added in order to activate the ports?
    Any advice welcome.
  • foshland
    • Jan 2017
    • 122
    • Spain
    Re: Repopulating SATA ports -- HP 800 G2 SFF.
    Hi, try saving the bios from the SFF and install the TWR version, maybe it works, if not, turn back to SFF bios.
    Soldering a sata port will not tell the board that there is a new sata port, so that should have been the last thing to do, first let the motherboard know it has 5 ports.
    In worst case you can buy a PCIex to Sata card, I know that is not what you want, but its the worst scenario solution.
    • ipmungam
      • Nov 2021
      • 8
      Thanks -- I agree, whether or not the pad is populated shouldn't change what the bios recognises, but when I checked the HP site the TWR bios update had the same file name as the SFF, so I thought something else might be going on. I will try the TWR bios and see.
      • piernov
        • Jan 2016
        • 4437
        • France
        Could be set by feature byte, could be set by strapping resistor.
        • ipmungam
          • Nov 2021
          • 8
          Thanks again -- checked the MD5 fingerprint of the latest TWR and SFF BIOS update files from HP and they are the same, so presumably identical (indeed, HP refers to the BIOS update as "TWR/SFF").
          I am unfamiliar with feature byte, guessing the BIOS updater reads this from the motherboard before flashing? In that case, would appreciate being pointed to any known work-arounds.
          I also searched for high resolution photos of the SATA ports on the TWR motherboard in order to look for any different SMD components, but didn't find anything conclusive. If anyone happens to have the TWR motherboard and wouldn't mind taking some clear snaps of the SATA port area would be much appreciated.
          • piernov
            • Jan 2016
            • 4437
            • France
            Feature byte is part of DMI info. BIOS update from manufacturer doesn't contain any DMI info. Full dump from another board will contain the associated feature byte.
            Strapping resistor if it exists will usually be near EC or PCH, even then it may simply be a difference in resistance (rather than a resistor being populated or not) to set board variant.
            • ipmungam
              • Nov 2021
              • 8
              Hello again -- update on my HP 800 G2 SFF. I never got the new SATA ports working, as piernov pointed out it requires more than a bios update.
              It does look like I did however cause some corrosion on the motherboard, and a while ago what looked like a SMD capacitor blew up near the SATA ports. I replaced it with one of the same size (no idea what the value is supposed to be) and it worked again, at least for a while.
              Now the computer won't start, emitting HP's 3 short 4 long beep code -- apparently this means a power problem. I removed all the components: if the CPU is not present, it gives the 3 short 5 long beep code indicating there is no CPU -- that's good. But as soon as I put a CPU in, I get the 3 short and 4 long -- tried a different CPU and a different power supply, no change.
              I can't see any physical damage on the board, and haven't found any obvious shorts on the VRM coils. Any suggestions on how to track this fault down? Is the fact that it works (that is, doesn't work) as it should without a CPU, but then complains about a power issue when a CPU is present (and nothing else; no memory, no drives, no CMOS battery) a hint?
              • DynaxSC
                GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                by DynaxSC
                I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                The board is generally working now, all PCIe ports are working, Windows installs normally.
                However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                03-10-2025, 12:27 PM
                Alienware 5 Notebook Specification for Upgrade or Repair
                This specification for the Alienware 5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 boardview and 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 5 Notebook is accurate,...
                09-06-2024, 05:40 AM
                LG N series 15N540-UT70K Notebook Specification for Upgrade or Repair
                This specification for the LG N series 15N540-UT70K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15N540-UT70K boardview and 15N540-UT70K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
                ASUS VivoBook N580GD-E4104T Notebook Pro Specification for Upgrade or Repair
                This specification for the ASUS VivoBook N580GD-E4104T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the N580GD-E4104T boardview and N580GD-E4104T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 08:32 AM
