XFX RX 5700XT No Display
Re: XFX RX 5700XT No Display
Now this is what i'm assuming as this has reached outside my league. i would wait for someone with more knowledge to assist here.Comment
Ok now check with multimeter on resistance mode if the side which gave the wave signal and pin 6 of the bios chip have a direct contact. should look like a short. I would say test Pin 6 again too if required.
Yes , it has resistance and quite big (6,12 mohms)Comment
(Try it with a mining adapter in single PCIe lane mode
Have a look at the resistance to ground (use doide mode) on all the PCIe lanes - both the side which has a direct connection and the side which has the little capacitors on each pair of tracks. On this check from the capacitor to ground, not ht ePCIe finger to ground. They should all read the same - any reading different suggests bad GPU
Have a look at the reset signal coming from the PCIe (SMRST) it is usually ANDed with the Power Good coming from the last vrm to power up - check as best you can this is getting to the GPU) .
I will attach a photo with what I think I should measure in diode mode . Is this pcie lanes (with green circle around them) ?Comment
Have a look at the resistance to ground (use doide mode) on all the PCIe lanes - both the side which has a direct connection and the side which has the little capacitors on each pair of tracks. On this check from the capacitor to ground, not ht ePCIe finger to ground. They should all read the same - any reading different suggests bad GPUComment
Sadly there is no schematics for this card as I was searching the interenet . Some specialist here on forum sent me a private message on what to test , but I cannot understand quite well . Maybe you can help me out on this :
For now i have attached a typical schematic which connects a crystal Oscillator to GPU and GPU to BIOS Chip. This is a typical circuit diagram which is commonly used on graphic cards. I will post a 5700XT schematic diagram of another GPU when i get home in the evening. Most part in the schematic is same or similar and can help in diagnosing this issue.Last edited by frazerxavier; 01-29-2022, 02:54 AM.Comment
here is a board view for MSI RX 5700XT. the layout is not the same but the connections are similar. If anyone else has a schematic for XFX 5700XT please post.Attached FilesComment
I measured the lines from the pice , and they seems good . but I don`t know how to check this out : "Have a look at the reset signal coming from the PCIe (SMRST) it is usually ANDed with the Power Good coming from the last vrm to power up - check as best you can this is getting to the GPU" any ideas ?Comment
I think the rest pin is the one of the last 3 pins on the right side of the PCIE lane at the back of the card towards the cut side where the 12V and 3.3 volt set is. I have attached a pic for your reference circuled in red. I'm not sure which one but it can be checked using a schematics any 5700xt schismatics would do as this part would be the same for all. i may have one 5700xt not xfx but some other. i will post here when i get home in the evening.Comment
So a friend told me to remove this U100 little part and order a new one as he had similar experience . After I removed it , the motherboard now boots but still card isn`t detected . I will order from aliexpress the part and see what is happening after I receive itComment
Let me know what happens after its replaced.Comment
Quick update on the thread here . I remember I have an RX480 RED Devil waiting for mosftets and drivers that are just ordered and the U100 (74AUP1G57GM) part is the same as the RX5700 . So I just took it off the Red Devil and put it on the XFX 5700 and it works now . Thanks all for help and cheersComment
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-56 - (Intel Core i5-11300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650 4G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-56 - (Intel Core i5-11300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650 4G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-56 - (Intel Core i5-11300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce...09-06-2024, 11:40 PM
This specification for the Acer Predator Predator Helios 300 PH315-53 - (Intel Core i7-10750H, 16 GB, 512GB PCIe NVMe SSD + 1TB HDD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Predator Helios 300 PH315-53 - (Intel Core i7-10750H, 16 GB, 512GB PCIe NVMe SSD + 1TB HDD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Predator Helios 300 PH315-53 - (Intel...09-06-2024, 10:20 PM
This specification for the Acer Aspire Intel Core i5-10300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650Ti 4G, 15.6" FHD IPS Display, Windows 10, Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Intel Core i5-10300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650Ti 4G, 15.6" FHD IPS Display, Windows 10, Black boardview and Intel Core i5-10300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650Ti 4G, 15.6" FHD IPS Display, Windows 10, Black schematic....09-06-2024, 11:20 PM
- Loading...
