So I have this GTX 570 The original fault was resistance to ground from Vram of just 10 ohms. Vcore was 1 ohm.
I traced that problem to the VRM controller IC for Vram (had a hole blown in it) and also the two VRAM phases had high side mosfet short to gate
So I removed the Mosfets and controller and Vram now had 60 ohm to ground, which seems reasonable enough
Understanding that I could have a faulty GPU and/or RAM due to the high side mosfet short, I decided to replace the APW7088 control IC plus the Highside (K03B9) and low Side (K0382) mosfets anyway
I checked all resistances were OK, still had 60 ohm Vram to ground, no short from 12V to Vram - so I powered it up
I found I had Vram of 1.5V.... for about 5 seconds then the PC powered down
Now I can't get the PC to power up with the graphics card fitted. I don't see any shorts - Vcore is reading 0.8-1R
I also noticed if I remove graphics card from the PCIe slot but leave the 12V 6 pin cables connected to it, then the PC will power up
If I plug the graphics card into the PCIe without the 12v cables attached the PC will not power up. The CPU fan spins for less than a second then stops)
If I put another graphics card in the PC powers up
I checked the 12V and 5V from the GTX 570 PCIe connector to ground. I have 60R (12V pins) and around 190R (3.3V pin)
So there are no shorts that I can see - but it still stops the PC from powering up
