problem with HP Z240 workstation
  • saidbe
    • May 2017
    • 42
    • Chilo
    I have a problem with HP Z240 workstation .
    it takes 15 min before the HP logo appears.
    i have done all the basic work (change cpu/ram/ CMOS clear..etc)
    Bios problem?
  • mon2
    • 14412
    Re: problem with HP Z240 workstation
    Go into your bios setup and note the setting of your drives / boot order, etc.
    Note the location of your drive cables and remove them all. Then power up again. Does this allow for your logic board to boot up faster?
    Perhaps one of the drives is causing this delayed power up. We have seen this with older boxes with RAID support and at least one of the drives was failing.
    • saidbe
      • May 2017
      • 42
      • Chilo
      thanks for your reply.
      i had a bin file from other computer, i reprogramme the BIOS. Now it takes one minute to appears HP logo.
      One minute is not normal and I get now this error:
      ERROR: SOFT TEMPORARY DISABLE: To enable ME, check Active Management (AMT) option in Setup (F10)
        • 21299
        The bios you tried may be from the same type of PC but you can`t just swap it and expect it to work ok.Part of the bios contains firmware called Intel Management Engine ,or ME for short.When the intel PC/laptop is first booted the ME firmware is married to the chipset,its then called "initialised". The bios needs the ME firmware "cleaning" .Post your original and new bios in the "BIOS & Schematic Requests!" forum here and someone will sort it out for you - https://www.badcaps.net/forum/forumdisplay.php?f=15
        • saidbe
          • May 2017
          • 42
          • Chilo
          Thank you.
          But one minute is long for appearing hp logo.
          I will post the file in the correct section.
          Can I do it self? Some guide maybe
            • 21299
            Yes there`s a guide - https://www.badcaps.net/forum/showthread.php?t=88533 .Use MEAnalyzer first to check which ME firmware version you need, then get the tools and firmware and follow the win-raid guide https://winraid.level1techs.com/t/gu...lization/31277
              HP Z240 Tower Workstation E3-1245V5 Specification for Upgrade or Repair
              This specification for the HP Z240 Tower Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation boardview and Z240 Tower Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-12-2024, 03:44 PM
              HP Z240 Tower Workstation i7-6700K Specification for Upgrade or Repair
              HP Z240 Tower Workstation i5-6500 Specification for Upgrade or Repair
              HP Z240 Tower Workstation i7-7700 Specification for Upgrade or Repair
              HP Z240 Tower Workstation i7-7700K Specification for Upgrade or Repair
