Asus H97M-E no display
  • Zibbo
    • Mar 2017
    • 204
    • Zimbabwe
    I have a desktop motherboard Asus H97M-E that has no display on VGA, HDMI nor DVI ports. The buzzer beeps once and the Caps Lock light responds to key strokes.
    I have tried an external graphics card and still no display, I have also flashed several bios dumps.
    What checks should I make? I have attached the boardview below.
  • Electronic Hardware
    • Aug 2021
    • Myanmar
    Re: Asus H97M-E no display
    hello! I've the same error. No post on asus H97M-E.After bios flashed,it's still the same error.Change new RAM and CPU but it's not ok.Which part of motherboard should i check?
    • anikin73
      • Mar 2022
      • 112
      • singapore
      first if you have a beep, it means it completed the whole booting power up process and going int running the bios. this type of error , you should consider cleaning and ram slot and cpu / cpu pins .
      you can also check if pcie A11 pins has 3.3 v. if it has, it means power up complete and it means all voltage are ok. it is the bios sequence issue. it could be stuck at ram or cpu ..
