A1418 Display not detected
  • knoxy
    • Nov 2017
    • 6
    • US
    Having trouble with an imac a1418 (820-4668-A).
    Backlight will flash on on first startup but otherwise the internal DP port is not working. Connecting to an external display works just fine.
    Replaced:
    F4400 with 0ohm resistor (Fuse was blown)
    Display panel with known working display
    Display connecter cable
    Display connecter on mainboard
    Curiously I am getting 12v on PP12V_LCD_F but only 7v on PP12V_LCD when the display is connected (Measured on either side of L4400)
    Does that sound right and does anyone have any other ideas?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: A1418 Display not detected
    Fuse probably blew for a reason. Not really a good idea to replace with a 0 ohm resistor. Measure resistance across it to check if it's gone bad again.
    Measure resistance across L4400, and measure resistance to ground after L4400 with and without LCD connected.
