Asus X99A/USB 3.1 repair
  • Bighairyorangutan
    • May 2024
    Hi
    I recently acquired a second hand X99A that had been previously working but not switched on for a few years.
    When booting it gets stuck with error code b6 - cleanup NVRAM, along with the memory light being on.
    I've tried removing the CMOS battery and resetting the clock via the jumpers but only once has it ever done anything different than error code b6.
    I've tried stripping the board, using different RAM and PSU. I've pressed the MeemOK button to try have default RAM settings. Only thing I haven't tried is an alternative CPU.
    Having looked at the useful repair guides and boardview schematics, I'm finding that the ME voltage on the PU501 chip can be anything from 0.4V to over 4V. I think only 1 of the pins actually had 1.05V.
    Is it worth changing the PU501 chip? or has anyone else had any joy with other solutions? Any help would be appreciated.
  • anikin73
    • Mar 2022
    • 112
    • singapore
    First the output of the chip is 1.05v. There should be an inductor with it. If it is 1.05v, it is normal.
    2nd if led stuck at vram,likely is ram issue or bios. Flash bios is surely easier then trouble shooting ram slot. Since this board had not been used, please clean the ram slot properly of the oxidation. It is likely ram slot issue.
    • Bighairyorangutan
      • May 2024
      Hi anakin
      I'm getting 1.05v on pin 5 of PU501 and the associated inductor. I'm also getting 5v going into PU501. About 3.3V on pin 8 (S_APWROK) but all other outputs expected to be 1.05 seem to be 0.4V.
      RAM slots are clean. And i've tried flashing the latest bios using flashback. this seemed to flash successfully.
