Bios File for Asrock Motherboard too big
  • victor-r
    • Apr 2014
    • 51
    • Portugal
    Please I need a tip, bios file for Askock motherboard too big for the chip, do I have to use the same tool, (UefiTool) for .CAP files?
    • 21986
    You`ll have to post more info than that. What model is the motherboard,what part number is the bios chip, where is the bios from that you`re wanting to flash is it from the ASRock support page - post a link to it .
    • victor-r
      • Apr 2014
      • 51
      • Portugal
      I understand, the motherboard in question is in a loop and I wanted to make sure that the bios would not be corrupted, so the normal update method will not be possible with just a bios recorder, the motherboard (Asrock H87 Pro4) is old but I wanted to recover
      • victor-r
        • Apr 2014
        • 51
        • Portugal
        The bios files that I downloaded have a size larger than that supported by the bios and that's my difficulty, I have to convert to the supported size but they are worse than the original, will it have to be another program for the conversion other than UEFITool
        thanks for answering
        • DynaxSC
          • Apr 2021
          • 477
          • Poland
          It's very strange, as far as I know only ASUS uses an encapsulation (.cap). Look on the support site, if there is not a different version. For such older boards there were some DOS programs to upgrade the BIOS, and they needed somtimes a dedicated file version. Maybe you just picked such a file version instead of a pure .bin container ?
          UEFITool might not help here, as as far as I know it can only handle the ASUS .cap encapsulation. But you can try to read the file with UEFITool to see if it recognizes the file at all and disassembless the bios content.
          Or maybe your board has two bios chips, and the content is divided between them ? ASUS used such a solution on many boards.
            • 21986
            For bios H87Pro42.40 delete 0 - FFF with a hex editor
            • victor-r
              • Apr 2014
              • 51
              • Portugal
              ok I'll try thanks
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
              • valdeson
                Good evening, I need a BIOS file for the motherboard som-6867 rev-a1 19a6686701-01 from the brand Advatech.
                by valdeson
                I request the BIOS file for the motherboard som-6867 rev-a1 19a6686701-01 from the brand Advatech.
                09-24-2025, 07:12 PM
