Reading and Programming ASUS iRog chips - EPF035 / EPF 036
  • artesano1969
    • May 2023
    • 15
    • Spain
    Well, I think this is the first time I'm sharing something here, I hope it will help anyone that, like me, is trying to repair one of those damm ASUS motherboards filled with iRog chips. I've written a manual following my experience and findings on fixing a dead ASUS Rampage IV Extreme (R4E).
    The ZIP file contains the guide and (almost) all the software I've used in the project. But I think it's worthy because it took me a lot of time to find out a cheap way to work with these chips from Explore with a bare CH341A programmer, and the original EP Console program is really hard to find.
    So enjoy it :-) I will come back from time to time, just in case someone needs more help with the matter.
    Best regards
  • huaji62
    • Aug 2024
    • China
    Do I need to change the OP_MODE pin level to put him into ICP mode?
    • artesano1969
      • May 2023
      • 15
      • Spain
      Yes. In order to read or write opmode has to be high. And it has to be set on power up. In the Asus boards I've tried, it's easy because they have headers that provide 3.3v next to opmode header. I hope it helps.
      • tuananh1333
        • Apr 2023
        • VietNam
        I have 2 rampage v edition 10 (x99 platform) have issue. All voltage present exept vcore and vmem. Board stuck at code 00.
        Refer to boardview file of similar board (rampage v extreme) i think enable of vcore somehow relate to the TPU chip.
        i can read/write firmware to the eeprom chip, but i can not find anywhere the know-good firmware for the board.
        can you give me some tips?
        i think the firmware for iROG chip can get from bios file but right now i dont know how to extract it.
        • huaji62
          • Aug 2024
          • China
          This requires extracting the firmware from a good motherboard and downloading it to this motherboard you have. The EEPROM connected to the EPF chip only holds the configuration file, not the firmware, the real firmware is only inside the chip.The BIOS isn't sure if it has that firmware, if it does it may be an IAP to upgrade the firmware via the LPC bus. I'm not familiar with 8051 core microcontrollers, so I can't analyze the existing firmware to see if it's upgradable.
          • Roman555
            • Jul 2023
            • 20
            • Ukraine
            GiveMeArray utility (by koryo) may be helpful to convert dumps from HEX-format into BIN-format
            • tuananh1333
              • Apr 2023
              • VietNam
              Thank you. Unfortunately my mb have dead chipset. Actually 2 r5e10 boards have dead chipset.
              i just order chipset from china.
              • artesano1969
                • May 2023
                • 15
                • Spain
                Hi tuananh
                I'm currently away so I cannot provide much help. I've got dumps for R5E that I can share and maybe they'll work in R5E Ed.10 boards -at least, they could work just enough to enable flashback, so you can then flash the whole BIOS using it. I haven't tested them, though.
                I've got an R5E Ed.10 but I haven't got the time to produce dumps for it (it's currently in use in a "home server" so it's kind of a little hassle to extract them).
                Regards
                • Roman555
                  • Jul 2023
                  • 20
                  • Ukraine
                  That's right. Download from ASUS site or dump the BIOS and then unpack the image using UEFIExtract. Choose old versions of UEFIExtract. Next, using your favorite tools find in the folder all files of 64KiB or 128KiB size precisely. A hexeditor helps to compare iROG chip dump and those chunks. Because ASUS BIOS doesn't hold all necessary parts of iROG firmware.
                  Attached UEFIExtract.
                  • McSaird
                    • Oct 2022
                    • 6
                    • Russia
                    Best regards
                    Thank you, kind person!
                    I was just looking for information on how to flash EPF021 on a laptop.​
                    MSI GP62M
                    I'll try to do it using your analogy, if it works out, I'll definitely write about it.
                    PS: I bought a Vertyanov programmer (successor base 3), but it can’t work with such microcircuits.
                    • McSaird
                      • Oct 2022
                      • 6
                      • Russia
                      Best regards
                      It working)
                      https://*******/viewtopic.php?f=60&t=148899
                      I will translate it into English and write a post here
                      • Artem Zaykevich
                        • Apr 2024
                        • Ukraine
                        Best regards
                        So what is steam for the MAXIMUS IV EXTREME-Z board?
                        • artesano1969
                          • May 2023
                          • 15
                          • Spain
                          Hello Artem. I presume you need the firmware for that extreme z, right? It happens that I have a working one, so I Will try to extract It this weekend and post It here. Best regards
                          Pablo
                          • artesano1969
                            • May 2023
                            • 15
                            • Spain
                            Hello Artem,
                            I've got some time so I'm attching here the dump I've done from my Asus Maximus IV Extreme-Z. Just tell me if you need any help with it, but following my guide you should be able to flash the EPFs. I've added also the dump of a SPI flash (just in case) and a boardview capture so you can recognize each chip in the dump.
                            I hope this helps :-)
                            Best regards
                            • Ros2468
                              • Feb 2022
                              • 16
                              • Norway
                              Hello, i need for firmware for maximus formula vi m6f i think.
