Gigabyte GA-7VKMLS Recap
  • Birdyman
    • Jan 2007
    • 20
    Well, I decided to do the kids Gigabyte GA-7VKMLS board tonight. The "before" state wasn't really much to talk about as there weren't any real problems with the machine. All the caps looked in good shape. Had Sanyo WG series for the 3300uF and 1200 uF, and Supacon for the 1000uF. Decided that I might as well do it now rather than chance getting into the mess I got into with my GA-7VAXP (see my other post).
    So why recap a working machine? Well, the kids had a problem with some random reboots a few months back, but they seemed to go away after I [by chance] removed the power supply and reinstalled it. However, I don't really buy that as a true fix. What I believe is that the problems were just the leading edge of a hardware [capacitor] issue that would likely get worse with time. I know that the MINIDUMP history of my GA-7VAXP showed the exact same behavior ... brief periods of problems followed by long periods of nothing ... until the caps were on their last leg. Of course, only then did the problems got progressively worse (albeit slowly) over a period of 6 months. If you've spent any time in the electronics industry, I'm sure you have run across this behavior. It's the nature of the hardware beast.
    Attached are some pics of the recapped board. No problems recapping. Disassembled system, recapped, reassembled, and POST in around 3 hours. Used a 40W solder iron with pencil tip. Heated old cap leads from underside of board using a "wet" solder tip (i.e., has a little solder on the tip) and gently rocked caps back and forth out of board. Used wet tip and rocking procedure to get new caps in. Once installed, I trimmed all new leads to around 1.5-2.0mm. Then I fluxed, and used a wet solder tip touched the tip of the new cap lead. I did have to worked a little harder to get solder onto a few of the cap leads, but I always finished the joint by heating the tip of the cap lead - the joint fills in nicely doing it like this. I used no-clean flux and solder, but I'm anal, so I cleaned the new joints with some board cleaner. Finally I TRIPLE CHECKED ALL JOINTS looking for NO SOLDER, LOOSE JOINT, EXCESS SOLDER, SOLDER ON ADJACENT AREAS, DESOLDERING OF NON-TARGET COMPONENTS, and PROPER CAPCITOR LOCATION. Yes I actually installed one of the new caps in the wrong location - thank goodness Gigabyte had a hi-res image of the board on their site!
    Enjoy!
    If it can be assembled, it can be disassembled.
  • DynaxSC
    GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
    by DynaxSC
    I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
    General test conditions:
    - Tested with Core i5 6500 and Core I7 6700K - no difference
    - Default BIOS settings, but tried also altering several memory setting - does not change anything
    What is wrong:
    With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
    When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
    03-21-2025, 06:23 PM
    Thermal pad thickness for various laptop GPU / Graphics Cards
    ASUS Dual RTX 2070 OC 8GB
    ASUS ROG STRIX RTX 3080 OC
    ASUS ROG STRIX RTX 3090
    ASUS TUF Gaming RTX 3080 OC Edition
    ASUS TUF GTX 1660 S-O6G GAMING
    EVGA RTX 3060 Ti XC GAMING 8GB
    EVGA RTX 3060 XC GAMING 12GB GDDR6
    EVGA RTX 3080 FTW3 ULTRA GAMING
    EVGA RTX 3080 TI FTW3 ULTRA GAMING
    EVGA RTX 3090 XC3 ULTRA GAMING 24GB
    Gainward RTX 2080 Phoenix GS Specs
    Gainward RTX 3070 Phoenix 8GB
    Gainward RTX 3080 Ti Phoenix
    GIGABYTE AORUS RTX 3080 MASTER 10G
    02-09-2024, 08:08 AM
  • corrize
    Best way to solder LVDS connector for beginner (and qfn) ?
    by corrize
    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
    See the test :
    https://youtu.be/bNAzC-EvqHs?t=1767
    With hot air from bellow the board, that's...
    03-09-2023, 02:57 AM
  • nikovmiroslav
    Gigabyte A5 X1 Need Bios
    by nikovmiroslav
    Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
    Gigabyte A5 X1
    From motherboard:
    S/N: 1TNH55ER1350895
    P/N: 6-77-NH55ERQY-D02-2CGB
    On sticker from the back of the laptop:
    S/N: SN21351J000657...
    08-24-2025, 09:15 AM
    Gigabyte Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
    09-07-2024, 07:19 AM
