Asus IPILP-AR
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Asus IPILP-AR
    Trashpicked a HP Slimline s3110.sc a while ago. It had a cooked Asus gf7500le card in it that i pulled out. The psu wires were cut of so i rewired the psu and it worked nice for a while, i had linux running from a usb stick. Then i stopped using it and it sat in the closet for about 3 months. Now that is pulled it out, it doesnt work anymore Put some ram in the little guy and powered it on, but got nothing on the display. DAFAQ? If i turn it on, the fan starts slow, sometimes high, and then gets slow. It speeds up and slows down a couple of times and then just stays on slow. No picture on the screen, and the power LED is orange. The caps seem to be good, this motherboard has all solid caps in the vrm and the rest are also solid or united chemicon. I am not suspecting the caps. What could be the problem? I have no idea. spec: c2d e6320, 2gb ddr2, no hdd, 180w psu, Ipilp-ar itx board. Anyone knows what to do? Nice little pc, dont want to throw it out.
    I can put text here?!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Asus IPILP-AR
    R-cap the PSU. I have all the part numbers if you're interested, as I gave re-capped this model before.
    Post a pic of the motherboard -- some of them use KZG by the VRM.
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      Re: Asus IPILP-AR
      I think mine has solid in the vrm. U.c. are near there too. Im going to check it tomorrow. Sure a psu recap is needed? Pics of the board and psu will come tomorrow.
      • mockingbird
        • Dec 2008
        • 5484
        Re: Asus IPILP-AR
        Yes. IIRC, you should find bloated Taicons in there.
        • mockingbird
          • Dec 2008
          • 5484
          Re: Asus IPILP-AR
          I just dug up my diagram for the PSU...
          13 caps in total, minus the primary which you should leave alone...
          Combination of all Ltec and Taicon caps. Caps on the VRM low are polymers, but the VRM high caps might be UCC KZG series, in which case they should be replaced... The system I repaired is still alive and kicking, the customer brought it in a month ago for a Windows 7 upgrade. He loves the tiny thing.
          • DJduck
            • Dec 2012
            • 229
            • Estonia
            Re: Asus IPILP-AR
            Ok, im going to dig it out of my computer closet now and take some pictures. Im going to replace the UC KZGs first, i have some rubycom MBZs that i salvaged from a dead MSI K something series board (i think ) And if that does not help, then the psu caps. The psu is kind of nice actually, except the caps. It's a Delta, i have a delta 480w in my main pc (also hp) and its really well made.
            Edit: board picture http://www.upload.ee/image/2975592/Untitled_67.jpg
            the caps marked in red are UC and the rest are solid. VRM solids are 16v and 2.5v, other solids are 2.5v and 6.3v. UCs are KZG, KZE and KMG And are all 6.3v, except the sound card ones. They are 16v and 25v, but they are small and probably OK. I think i will replace them with rubycons, the ones that i got are wider in diameter and taller, but the leads are the same disdance apart, so it should be fine?
            • DJduck
              • Dec 2012
              • 229
              • Estonia
              Re: Asus IPILP-AR
              Also, can i replace 10v psu caps with 16v?
              Edit again: I checked the psu and no bloated caps in there. I also turned the computer on, and the fan is at full speed, and i had no memory in there. It did not beep. It should beep without memory!!!Ok, the kzg and kze are going rubys are going in!
              • mockingbird
                • Dec 2008
                • 5484
                Re: Asus IPILP-AR
                Leave the KZE... Only replace KZG...
                Yes, you can use a 16v cap instead of a 10v cap. I suggest you do a full PSU re-cap and plan it before just using random replacement parts.
