Re: Samsung 213T inverter
Hello Mork,
Look back in post #9 in this thread. https://www.badcaps.net/forum/showpo...44&postcount=9
There you will see how I replaced two mosfets on this inverter. I fixed many of these and some needed several mosfets replaced. Post a picture of your inverter if you can.
I'm posting here a picture of my 213T after the caps' substitution, showing a white screen.
I'm totally noob in electronics, but thanks to this forum i've been able to find a replacement for what seem bulged caps and let them subtitued by a technician...(i would have damaged something for having no experience at all in soldering etc.)
The magic is that before the cure the monitor was totally down (led on but no video at all) and now it's working!!! But, as you can see , the lower part of the monitor is darker...Someone suggests checking mosfets and replacing a fuse...are they cheap as caps? can someone please help me finding them on the board?
Thanks to this very useful comunity!
Thanks to this thread I have just fixed my 213T. On the beginning I replaced all six caps on the PSU and all four caps on the inverter board. Panel started to work but the upper part of LCD was much darker then lower. I checked mos-fets and and two of them was failed also. I replaced them and the fuse which protect them also and... panel has been recovered!
Thanks,
jaceksto
thank you very muchLeave a comment:
Yea it appears the they are non stocking now at DigiKey. Minimum order is 3000 pieces.... I do have a few spares if anyone needs some.Leave a comment:
Read thru the thread again. You almost certanly have a shorted mosfet on your inverter. Use my procedure to determine which one. You might also check between. the two leads of the inverter caps for a short (this will tell you what side of the board the shorted mosfet is on). I did over 30 of these and almost every one had a shorted mosfet as a result of the bad caps.Leave a comment:
I just checked voltage at the ceramic fuse on the PS board and on both sides the voltage is flickering between 2.5v to 2.8v. I am going to assume that is a problem?Last edited by Cybs; 12-15-2011, 01:29 PM.Leave a comment:
I was afraid you were going to say that. Those 4 caps were the only ones I bought locally and they were the only ones I could find.Leave a comment:
I'm having an issue with one of my 213ts.
Originally it had a fast blinking green light. I replaced the 6 PS caps (All were domed) and I replaced the 4 on the inverter board.
The problem then changed. There is still no display at all and now no green light. Since I happen to have 2 of these monitors (One still being good), I narrowed it down to the inverter board being bad. Any ideas?
I already checked for ring cracks at the power socket and I can't find a diagram of which parts are which for the inverter. In fact I can't find anything on the net for the interver board.
PlainBillLeave a comment:
1) check polarity of the caps you installed to make sure none were installed backwards.
2) check for any solder bridges that may be causing a short.
3) reseat the wiring harnesses between the power/signal/inverter boards.
4) if you used RadioShack caps or any other non low-esr caps, then that could be a possible source of your problem.Leave a comment:
I already checked for ring cracks at the power socket and I can't find a diagram of which parts are which for the inverter. In fact I can't find anything on the net for the interver board.Leave a comment:
Thanks,
jacekstoLeave a comment:
smamado,
The fuse blew because of one of the mosfets (one of the 8 'eight pin' SMD chips on the board) shorted. The mosfet failed because of the bad caps on the inverter board. See my picture as marked up. You will need to determine which mosfet shorted and replace it. Once you are sure the short has been fixed, you can replace or jumper the fuse. Since you say that both of your fuses are open, then you have shorted mosfets on both sides of the board. In my example only one side had a short.Last edited by bluto; 07-24-2011, 05:57 PM.Leave a comment:
Well I guess I need to correct my post a little. I read some of the other posts on measuring the resistance across the primaries on some of these transformers. It looks like low resistance is the norm here. So when I said that they were shorted (ie my continuity beeper went off), I actually mean that I get 2.1 ohms across the primaries and 2.6 ohms across the capacitor pads.
SteveLeave a comment:
I have had success repairing a couple of these inverters. I used AO4619 MOSFETS (http://search.digikey.com/scripts/Dk...=785-1044-1-ND) as replacements for the 4600's. Since I had several to do, I got some chipquik that worked very well getting the old ones off.
If you are fixing one of these, test for shorts between pins 2 to 3, 2 to 5-8, and 3 to 5-8 on all eight of the 4600 MOSFETs. Replace any that show a short. They seem to fail in pairs. You will also need to check the two SMD fuses and replace/jumper as necessary. Be sure to replace all the caps on the inverter and the power supply while you are at it.
Attached are a couple of pictures showing the replacement of the MOSFETS. Pins 5-8 are shorted by the board, so I went ahead and put a big blob of solder across them. They are a little crooked, but over all not bad for my first attempts at surface soldering. Do yourself a favor and replace the caps on the inverter after you have replaced the MOSFETS.
Thanks again to everyone who replied to this thread for their help.Leave a comment:
For a small job like this Chipquik is pretty expensive. For large pin count ICs it's the only way to go though.
A simpler way for smaller packages like these is to get a sewing needle blob up the 4 pins with solder put the needle underneath the pins if it won't press under just leave it in place. Then melt the solder press the needle under and lift until the pins clear the solder. For the other side just blob up the pins and remove the IC with tweezers.
Clean up the solder on the traces with desoldering braid and you're ready for reinstallation.
I use this method on up to 6 pin packages anything larger I use Chipquik.
I learned this from a guy when I used to replace Xbox HDDs since their EEPROM on the mobo was a 4 pin SMD package like this one. The ICs had to be removed intact since they contained the unlock code for the HDD.Last edited by Krankshaft; 02-23-2010, 08:18 AM.Leave a comment:
Originally posted by blutoOk it looks like that is an AO4600. And according to their site it is discontinued.
http://www.aosmd.com/web/products/pr...tree&tree_id=9
Possible replacements are listed as AO4619 and AO4622
Digikey has both. How do if figure out which one I need? The 4619 has 30v drain to source vs. the 4622 which has 20v. Otherwise they seem very similar. Looks like Digikey has Chip Quik also.
Plenty on Ebay
This link may help
http://cgi.ebay.co.uk/Lot-of-Two-2-A...item3350ad0589Leave a comment:
Digikey has both. How do if figure out which one I need? The 4619 has 30v drain to source vs. the 4622 which has 20v. Otherwise they seem very similar. Looks like Digikey has Chip Quik also.Leave a comment:
Originally posted by blutoWow you have a good eye! On further inspection, they do look burnt. There is discoloration on the bottom of the board in that exact spot. So it looks like they got hot. The part number is (@?) 4600 BE4T1B. Guess I am going to have to learn how to surface solder.
As for removing SMT components, a product called Chip Quik is excellent. It has reached the point where I would rather work with SMT components than through hole.
Wow you have a good eye! On further inspection, they do look burnt. There is discoloration on the bottom of the board in that exact spot. So it looks like they got hot. The part number is (@?) 4600 BE4T1B. Guess I am going to have to learn how to surface solder.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
