Originally posted by momaka
View Post
View Post
1. Does that means, that even if I find the chip with the same 'speed' like 1.4ns or same frequency, it MUST be made by the same chip manufacturer (in this example Samsung) or it can be from other manufacurer, just needs to be of the same specific (response and frequency)?
2. If I solder the wrong chip, what will happen? RAM wont work or somethign else would brake? Will the RAM module get tosted for good, or I could still remove the wrong chip andd after putting correct one, make the RAM work as it should?
View Post
Its really bad fact that just becuase Samsung wanted to spare $0.10 for that Zener diode, I got my main/logic board chip fried.
Your idea got me thinking.... is it possible to solder such Zener diode on the board (somewhere) and make that 'custom' over-voltage protection that Samsung 'forgot' to implement?
View Post
Just, thats before the power board is connected to anything else, correct? I mean, once the monitor power up, that FAT filter cap end up with much higher voltage, right?
Ok, that was it for now. I hope you didn't missed my long posts (ofcorse you didn't, I'm just joking).
Thanks again momaka, for all the patience you showed during long 2 (or is it 3?) months of dealing with me, while helping me to fix my monitor.
If there are no further responds to this topic, I may revive it again, once I get ahold of some hotair station so I can change those firmware chips on my monitor.
cheers!
