BenQ FP17E+ blank display
  • poulus
    • Nov 2009
    • 10
    Firstly - brilliant site and forums, I've lost hours over the last week looking through it I arrived here while looking for a fix for the above monitor. I've got a pair of them that I bought about 4 years ago as I like a big desktop
    Originally I thought the back-light had gone but once I dismantled it I realised there were 2 lights and they're a pig to get out so I investigated further. I did a bit of juggling of parts with its working twin and proved that the back-lights were OK. Googling led me to the Dell E172 and common 4 transistor problem but I also came across this:-
    http://www.electronicrepairguide.com...nq-fp71g+.html
    As the cap in that area is bulging and the board scorched where the transistor is I'll try that fix first.
    FYI the board is labelled 48.L0Y02.A02, the bulging cap is at C712 (Jamicon 1000uF 10V 105C 440C2(M) ) and the transistor is at IC701 (can't make out what it is but I'll go with the one in the above link).
    In Photo176a I think I'll add some extra holes in the marked area to help the convection airflow seeing as a lot of the problems seem to have an over-heating aspect.
    Paul
  • poulus
    • Nov 2009
    • 10
    Re: BenQ FP17E+ blank display
    BTW which would be the better replacement for the original cap:-
    http://uk.farnell.com/illinois-capac...-9b10-00001422
    or
    http://uk.farnell.com/multicomp/mcrh...tor/dp/1136251
    • poulus
      • Nov 2009
      • 10
      Oops, those last 2 links are no good as they'd cost me £15 in delivery. So gotta find a UK source.
      • poulus
        • Nov 2009
        • 10
        Nightmare!
        Anyone know where in the UK I can get both:-
        1 x FQU11P06
        1 x Cap (1000uF, 10V, 105c, 5mm pitch)
        without extortionate delivery charges and spares I won't need?
        • poulus
          • Nov 2009
          • 10
          OK, update.
          After struggling to get the tranny and cap I needed elsewhere I bit the bullet and ordered from RS. I figured I'd offset the cost of the minimum order quantity (5) by not paying any delivery charge as they have a trade counter near me. But that turned into an epic as some clown in their warehouse cancelled my order which took 3 visits to sort. Thanks to the nice young lady at the counter I've ended up with the caps and trannies for free and free delivery!
          So I did the repair mentioned in the earlier link and also enhanced the air flow as I mentioned in my first post. Additionally I've enlarged the vent holes in a couple of areas of the rear plastic shell to encourage a better air flow across the inverter board which should help. I also checked for dry joints and re-flowed the ones suggested. So now my monitor works again
          But now I notice its twin has pink tinge. So now I'll have to start messing about again checking leads, connections, etc. Any suggestion?
          BTW if anyone needs the cap and tranny for this repair let me know as these spares will sit unused in my spares bin for evermore
          • PlainBill
            • Feb 2009
            • 7034
            Originally posted by poulus
            OK, update.
            A pink tinge usually indicates CCFLs nearing the end of their life.
            PlainBill
            • hasel17
              CH341a can erase and read but can't write and blank check
              by hasel17
              So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
              Code:
              Checking for blank...
              (Press
              10-26-2023, 06:20 AM
            • magneh
              Behringer Eurolive B205D repair - help identifying transistor
              by magneh
              Hello
              Got this speaker from a friend , defective. Power led comes on and off , in a loop.
              Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
              After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
              I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
              Still, I need to replace this transistor....
              06-18-2025, 02:34 AM
            • RetroComputingGrotto
              Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
              by RetroComputingGrotto
              I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
              I've uploaded a video of it happening on YouTube:
              I've taken the monitor...
              01-11-2024, 05:37 AM
            • elsomer
              help to identify transistor msi ms-15ck1
              by elsomer
              hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
              02-17-2025, 05:30 PM
            • rddube
              Help with blowing transistor NAD T752 receiver
              by rddube
              I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
              Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
              I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
              09-01-2022, 05:19 AM
