Samsung P2570HD
  • The Eight-Bit Link
    • Nov 2016
    Samsung P2570HD
    Hey, I've a Samsung P2570HD that's got a bad problem. Attached is a video of what it's doing. When I replaced the caps it kept doing this but not as bad. Is there anything I'm missing? I'll try and take the transformer off to see if the coils are bad.
  • boyebaran
    • Sep 2015
    • 247
    • iran
    Re: Samsung P2570HD
    please check polarity of cap you changed it and soldering quality (dead solder) .
    check fixing flat cable connector to panel socket.
      • Nov 2016
      Re: Samsung P2570HD
      I tried ordering a replacement board, but the backlight would go black after two seconds. I tried Fixing it and somewhere I stopped getting voltage from the board at all. The fuses are fine. It seems the eight-pin regulator chip isn't running. Is there a way to check the FET it's connected to or if the chip is running?
        09-07-2024, 05:50 AM
      • unimatrix93
        Replacement transformer for Samsung fridge
        by unimatrix93
        Dear forum
        My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
        No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
        The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
        My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
        07-14-2025, 02:16 AM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
