Samsung 740N Inverter problem (blowning mosfets)
  • Honziq
    • May 2014
    • 65
    • Kazaksa
    i have samsung monitor with IP-35135B PSU.
    Display does not light, i changed bad caps, pico fuse, two mosfets (I use IRF7389), then monitor starts to work.
    But after few hours of using it was going black again. Mosfets are blown again.
    Thanks for help
  • Honziq
    • May 2014
    • 65
    • Kazaksa
    Re: Samsung 740N Inverter problem (blowning mosfets)
    Now I find bad solder on one of the coils, which makes a short circuit. I placed new mosfet and monitor is running again. Now I waiting what happens after few hours
      09-07-2024, 05:50 AM
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • vincentedel
      Samsung SyncMaster 740n Phase Control Issue
      by vincentedel
      I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
      I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
      04-22-2025, 12:33 AM
    • alro7779
      Samsung UN55MU6103F video problem; has colored stripes on the display
      by alro7779
      Hello, everyone!
      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
      09-27-2025, 11:29 PM
      09-06-2024, 11:40 PM
