Weird fault with Samsung SyncMaster S24B370
  • japlytic
    • Oct 2005
    • 2086
    http://youtu.be/Eh9QxtvLA5s
    This fault sometimes happens when the display wakes up from sleep mode and becomes good a few seconds to up to about a minute, and I have ruled out video drivers and the operating system because this fault happened when the computer was turned on from its "off" state.
    I have also ruled out a bad HDMI cable since this fault did not occur months earlier on.
    Have you seen such a fault?
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
    09-07-2024, 05:50 AM
  • soopacrucial
    Samsung Syncmaster 740BF repair
    by soopacrucial
    Hi folks,
    I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
    Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
    10-29-2024, 02:40 PM
    09-06-2024, 11:40 PM
