Samsung Syncmaster 712N Goes Bright
+ More Options
Posts
  • Jidis
    • Nov 2013
    • 63
    Trying to fix some more of this old junk or toss it out. Figured I'd see if anyone here had ever run into this issue:
    It's sort of like a backwards version of a dying backlight. The display will occasionally flash or flicker a couple times, then go super bright and really washed out looking. When I checked it before, I skimmed over it for bad looking electrolytics and cold joints, but didn't spot anything. I'll try to do a more thorough job of that in addition to testing it for temperature issues, but I think it had even done it from a cold boot as well as staying on for a while without doing it. It appears to go much brighter than anything you could do with software settings.
    Can that still be a backlight problem or is there any other specific part to check or replace?
    Thanks!
    George
    09-07-2024, 05:50 AM
  • soopacrucial
    Samsung Syncmaster 740BF repair
    by soopacrucial
    Hi folks,
    I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
    Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
    10-29-2024, 02:40 PM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
