WestingHouse 19" 19w4 LCD monitor- DAC-12M030
    replied
    Re: WestingHouse 19" 19w4 LCD monitor- DAC-12M030
    Great, and thanks for the feedback.
  • Soisauss
    replied
    And....IT LIVES!!!!!!!!!!!! To serve again!
    Thank you all for your help and to budm for guiding me step-by-step!
    This forum is worthy of its recognition!
  • Soisauss
    replied
    Just type in AO605 in EBAY search and select US only on the left pane. I.E.
    http://www.ebay.com/itm/5X-AOP605-P6...item2a15bf0e14
    Gotcha!! Thanks again!! Just ordered 4 and shall be here next week hopefully. Will report back.
    Thanks a bunch!
  • jetadm123
    replied
    http://www.ebay.com/itm/LOT-OF-2-AOP...item4ac5f61c37
    replied
  • Soisauss
    replied
    Originally posted by jetadm123 View Post
    There are several American sellers on eBay selling the AOP605.
    If you can link it, that's be awesome!
    Btw, thanks a ton for your help and patient Budm!! You are a trooper!!!
  • jetadm123
    replied
  • Soisauss
    replied
    Not sure how you read the scale to be the same as 1K range to get 0.6 on x100 scale, the 0.6 = 60 Ohms, 2.8 = 28 Ohms.
    At this points I would suggest to replace ALL 4 MOSFETs.
    Good question....
    Now the question is where can I get these mosfets without ordering from overseas in China (been reading some ebay reviews....and the result has my head scratching).
    replied
  • Soisauss
    replied
    They do look bad, but I forget to tell you to use x100 Ohms scale for checking, sorry about that. Can you test it again? Also try reversing the leads of the meter so you will report 4 set of readings.
    Okay, the setting is set to x100 Ohms.
    Meter probe on 1 (Black), then check the reading between
    1 and 2 = 45
    1 and 3 =48
    1 and 4 = 26
    1 and 5 = 26
    Meter probe on 6 (Black), then check the reading between
    6 and 2 = 2.8
    6 and 3 = 2.8
    6 and 4 = .6 *No Change
    6 and 5 = .6 *No Change
    Meter probe on 1 (Red), then check the reading between
    1 and 2 = 2.9
    1 and 3 =2.9
    1 and 4 = 2.79
    1 and 5 = 2.79
    Meter probe on 6 (Red), then check the reading between
    6 and 2 = 45
    6 and 3 = 45
    replied
  • Soisauss
    replied
    Okay, here are my readings. Using the same meter I've posted and using the green numbers on the meter.
    The setting were set to x1K ohms
    Meter probe on 1 (color does not matter), then check the reading between
    1 and 2 = 15
    1 and 3 =15
    1 and 4 = 6
    1 and 5 = 6
    Meter probe on 6 (color does not matter), then check the reading between
    6 and 2 = 2.5
    6 and 3 = 2.5
    6 and 4 = .6
    6 and 5 = .6
  • Soisauss
    replied
    Black probe on 1 and red probe on for example the one I mark as #2 will be any one of those 4 pins since all those 4 pins in the circle are connected together. As you can see, the 4 pins on the right side of the MOSFETs are tied together.
    Okay, cool beans. I'll report back with the readings!
    replied
  • Soisauss
    replied
    Here are the resistance test points
    1 and 2 = ???
    1 and 3 =???
    1 and 4 = ???
    1 and 5 = ???
    6 and 2 = ???
    6 and 3 = ???
    6 and 4 = ???
    6 and 5 = ???
    Make sure to tell us if it shows as Ohm, K Ohm, M Ohm.
    Okay, so the number 2-5, you want me to test each pin on said numbers right? For example, 1 and 2, Black will be on 1 and then I'll test each pin on 2 (which is 4) with red, correct?
    ^ That above is assuming you want me to follow the picture you've attached.
    Also, my meter only reads in OHM... :/
    replied
    1 and 2 = ???
    1 and 3 =???
    1 and 4 = ???
    1 and 5 = ???
    6 and 2 = ???
    6 and 3 = ???
    6 and 4 = ???
    6 and 5 = ???
  • Soisauss
    replied
    OK, that means the problem is in the inverter circuit that we isolate by lifitng the fuse. More likely to have the shorted out MOSFET which is very common problem as the other had suggested.
    So you need to take good resistance reading again using the pin out of the MOSFET spec and my drawing as the guide.
    Okay, what setting should I be using on my multimeter then? Should I continue to use the X1k Ohms setting?
    replied
  • Soisauss
    replied
    YUP!!! It stayed green and I can see my wallpaper!!!
  • Soisauss
    replied
    If you have it hook up to running PC, will it stay green? And let me guess, the power supply is not ticking any more, right?
    You are correct!!! There is no more ticking noise. Let me try to hook it up to the pc.
