Run LCD monitor with 2 CCFL out of 4
  • expert_vision
    • Jun 2013
    • 7
    I have one of those "2 seconds to black" problem, and is because 2 of the 4 CCFL are broken.
    The top 2 CCFL still works, and I was wondering, how can I fool the inverter IC that there are 4 lamps?
    The model of my power supply used by my monitor (Samsung 940N) is IP-35155A with the schematics attached.
    What voltage do I have to apply on pin3 - OLP (Open Lamp Protection) on the SEM2005 IC, to prevent the stopping?
    Also, why is there needed a protection for the inverter in case it doesn't have a load?
    On the inverter output it says, "650V~/7.5mA". Can't I use only 3mA?
  • expert_vision
    • Jun 2013
    • 7
    Re: Run LCD monitor with 2 CCFL out of 4
    "Incorporate open lamp and overload protection in the circuit design. Open
    lamp will cause full voltage in the transformer output and will burn the
    transformer."
    Ok, so I need a different inverter for 2 lamps, R C L load replacement (???), some actual CCFL replacements or replace the whole CCFL with LEDs power from 12V line that goes already in the inverter.
    Honestly, this CCFL is a lot of pain. Why was CCFL chosen over LED in LCDs? Is CCFL more reliable than LEDs?
    • expert_vision
      • Jun 2013
      • 7
      Dear lord, I'm actually thinking to convert my CCFL to LED strips. They seems quiet cheap. Bye bye inverter!
      • leapius
        • Aug 2012
        • 60
        • uk
        I have to agree with you about LED backlight debate. One advantage is better colour reproduction on CCFL. I did read about someone using a resistor in place of a bulb to provide the same load. You'd need to ask someone with more knowledge about specifics.
        Simply ripping out your bulbs and inverter and putting in a strip of LEDs can be done but it's not so easy as the a/v board and psu won't like it and will likely just shut off.
        • mariushm
          • May 2011
          • 3799
          When LCD monitors started to be made, the leds weren't that great.. not so efficient, color accuracy was bad and the white was hard to accomplish (white leds are blue with a layer of phosphorus inside)
          Nowadays it's much better.
          • expert_vision
            • Jun 2013
            • 7
            In the end, I bought a broken LCD with good lamps and replaced all 4 of them with practically brand new ones. So anyone out there with bad lamps I suggest you do the same, because if one lamp is out, pretty soon the others will fail too, so replace them all.
            Just find a broken LCD of the same size with good lamps. Basically, any LCD that has the same size and nr of lamps as yours, will have lamps that fit, but if you buy the same brand as yours it might make your life a little bit easier. I bought a different brand and I had to remove the lamps out of their housing and put them in the old one, which was a pain because I had to find a substitute for the rubber silicon that held them in place. I used hot glue, having no idea that laps gets so hot that they melt the glue. But is fine, because I also used some cardboard to keep the lamps separated, and the hot glue helps them stay together, even though it's melted.
            • keepread
              Dell monitor PSU vs Dell laptop PSU
              by keepread
              Hi there!
              Someone gave me their old monitor, it's Dell S2715ht.
              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
              10-30-2025, 04:45 PM
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
            • mikey5791
              Help on Samsung Syncmaster T220 dead ccfl lamp
              by mikey5791
              This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
              Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
              10-18-2020, 03:17 AM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • wattage
              by wattage
              Hello Badcaps Community,
              07-13-2025, 04:41 PM
