another Samsung 2233
  • tedmich
    • Dec 2011
    bought from Dell in part because of its 3y warranty , but now Samsung says its 1y and back light failed at 2.5y
    started to flicker a few days back, went black a few times and then re-fired. Now it flashes on and off and then goes totally black although display is still visible with a bright light.
    board is different than most I have seen.
    https://docs.google.com/open?id=0Bx4...E1OTZhZTBmYzVh
    2 fuses (circled) at least not tiny pico units and test OK. Pulled all the SAMYOUNG caps and they all test ok by simple LCR meter. Pulled the inverter transformer and got 1.115k for both S1-2 and S3-4 but P2 is shorted to P3 (zero ohms) and should be closer to 0.2-1.0 I believe. I think the Samsung 2243 uses the same transformer and will order one. Have new Nichicons coming from mouser too.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: another Samsung 2233
    We prefer pics hosted here so they are available for others in the future. Please use the manage attachment feature to upload and please do not post inline.
    We rarely see the primary side fail. It is mostly the secondaries that fail.
    When you touch your multimeter probes together, do you get 0.0 ohms?
    --- begin sig file ---
    --- end sig file ---
    • tedmich
      • Dec 2011
      I may not have the resolution to measure 0.2ohms, my cheap DMM doesn't have a zero knob or calibrated leads but the primaries read identically (0.4 ohms) P2/P2, P3/P3 and P2/P3 so it looks like continuity to me. If shorted primaries are unheard of, secondaries which seem to be ok by R measurement are more common right? I plan to replace transformer regardless, and caps too. Bad CCFL is always a possibility too, unless I test with good inverter.
      thanks for the tip on image hosting, I know of no other site which does this
      this is Samsung P# BN44-00296A
      • retiredcaps
        • Apr 2010
        • 9271
        If you still have a problem after replacing the caps, report the DC voltages on the 12 pin connector to see if we have stable power.
        • tedmich
          • Dec 2011
          replaced all the (low voltage EL) SAMYOUNG caps, only $13 from Norvac, but not my favorite brands, which I was ready to order from Mouser for $3.
          IT LIVES! THANKS ALL!
          • retiredcaps
            • Apr 2010
            • 9271
            IT LIVES!
            Good job. Glad you got it working.
            • tedmich
              • Dec 2011
              postscript, I need a decent DMM which can measure low R values!
              0.2 ohms does not equal 0 ohms!!
              this can help:
              http://www.keithley.com/data?asset=53682
              think I'll make a 100mA CCS with an LT3092 and a couple precision resistors 2k/20k and a 9v battery
