I believe the caps are going bad in my Samsung T220, how long will it last?
  • StealthStalker
    • Oct 2011
    The title says it all basically. How long will the capacitors last in their current state, if this is indeed the problem?
    Here's the situation:
    My T220's screen will turn off after a short duration following a power-on. The LED light remains on, so it's just the screen/backlight that turns off. The length of time it remains on before shutting off depends on the duration of time it was previously left powered down.
    I currently get around this by, what I assume is, charging the capacitors a little. The T220 comes with the buttons on the right side for navigating the menu/settings for the monitor (brightness, contrast, other settings, etc). One of the buttons (third one down, of four) is a button that will cycle the input from digital to analog.
    I press this button, and it will cycle from digital -> analog -> back to digital. Doing so turns the screen/backlight back on when it swaps back to digital without actually powering down. I do this a few times, and then the monitor will remain on with no issue until I turn it off again for an extended period of time.
    The # of times I must cycle it after turning it on, again, is related to the length of time it has previously been turned off.
    I do not know anything about hardware/capacitors and such, but as you can see my research on the issue has lead me here. I can only assume the issue is related to my capacitors, and I'm wondering how long I can go with my current method of cycling the input until they're done for good and I should search for a replacement.
    Even if they may last for a bit longer, could my current method endanger other components? Should I seek to try and repair the capacitors sooner rather than later?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: I believe the caps are going bad in my Samsung T220, how long will it last?
    It could be capacitors. You will have to open up the monitor and look at them.
    If you continue to run the monitor with your current workaround, you could damage other components inside.
    You can post pictures here and member can help you. Please follow the guidelines in my sig file below.
    --- begin sig file ---
    --- end sig file ---
    • StealthStalker
      • Oct 2011
      Yep, I'll try and get to it sometime soonish. Only monitor I have at the moment, so I'll see what I can do.
      Thanks.
      • retiredcaps
        • Apr 2010
        • 9271
        For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
        Here is an example of the pictures we want.
        https://www.badcaps.net/forum/showpo...94&postcount=1
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 06:20 PM
